Results 16 to 30 of 43
  1. #16
    Nov 2008
    Perth WA
    6,459
    It looks the part Techo.
    How will you hold the 40 arbor while machining the Wohl mount?
    Bob.
  2. #17
    Sep 2008
    Riddells Creek, Vic.
    838
    Bob, after the internal 16mm drawbar thread is cut I will pull the shank back against it's 65mm diameter flat face on a faceplate. Holding the shanks for grinding after hardening will be another story.
  3. #18
    Nov 2008
    Perth WA
    6,459
    Quote Originally Posted by Techo1 View Post
    The advantage of having a largish lathe!
  4. #19
    Sep 2008
    838
    A little more progress on the shanks, this is the setup I used to bore, drill and screw cut to ensure that the threaded hole stays concentric and straight.
  5. #20
    Sep 2008
    838
    The 2 shanks are ready for Carburizing, hopefully later this week.
  6. #21
    Sep 2008
    838
    Pack Carburizing at 910 degrees C today.
  7. #22
    Sep 2008
    838
    They are now ready for Hardening and Tempering. I filled the threaded holes with Refractory Cement (Fire Clay) to prevent extra carbon being absorbed by the threads which could make them very brittle.
  8. #23
    near Rockhampton
    6,218
    You did quench them after pulling them from the furnace?
  9. #24
    Sep 2008
    838
    No, I didn't, they were allowed to cool overnight while still in the box. Today I reheated them to 860 degrees and quenched in oil to refine the core, tomorrow I will reheat to around 800 degrees and quench to refine the case. They will then be tempered.
  10. #25
    Sep 2008
    838
    Grinding the #4MT shank.
    Various stages of completion.
  11. #26
    Nov 2008
    Perth WA
    6,459
    Very nice Techo!
    How are you supporting the tailstock end of the arbors, a dummy centre screwed into the drawbar thread or the tailstock's centre running off a chamfer at the entrance to the bore? I like the hose clamp "dog". One to remember.
    Bob.
  12. #27
    Sep 2008
    838
    Yes Bob,it's running between dead centres on the 60 degree chamfers machined in each end.
  13. #28
    Sep 2008
    838
    Default Every Home machinist should have one of these.
    Attachment 370405
    I was having second thoughts about the scrap yard material I used for the two Wohlhaupter shanks/arbors considering I have had it for over 20 years and the colour coding on the end of the bar is almost completely worn off.
    A bit late I know, but I decided to have it tested to confirm that it was actually EN36A, the scan results are below.
    It came up as 9310, the AISI equivalent of EN36A so all is well. It appears that the XRF does not have European standards in its data base.
  14. #29
    May 2011
    Murray Bridge S Aust.
    5,959
    Unfortunately your attachment 370405 comes up with "Invalid Attachment specified. If you followed a valid link, please notify the administrator"
    Nice piece of workmanship on your shank/arbor. Thanks for the WIP report.
    That's an amazing interesting piece of equipment, as you say Every Home machinist should have one of these.
    I'll bet it wasn't cheap, or is it a work perk??
  15. #30
    Jan 2011
    Far West Wimmera
    63
    4,049
    A quick check shows prices from $8k to $22k for secondhand on US EBay. Would be handy to know of someone with such a machine. Steel merchant or similar. Could I just check this trailer load of scrap mystery metal?
  1. Wohlhaupter Models
    Last Post: 4th Jun 2014, 09:12 AM
  2. Wohlhaupter UPA5-S6
    By Ueee in forum METALWORK GENERAL
    Last Post: 25th Sep 2013, 01:24 AM
  3. Pictures of a Wohlhaupter box
    Last Post: 17th Feb 2013, 07:10 PM
  4. Wohlhaupter- Not a UPA
    Last Post: 21st Feb 2011, 06:18 PM
  5. Modifying a caravan to a flat bed
    By Chooks74 in forum TRAILERS & OTHER FABRICATED STUFF
    Last Post: 27th Jan 2009, 05:25 PM
