Results 1 to 11 of 11
Thread: my parting tool holder
13th Mar 2017, 09:23 AM #1Most Valued Member
- 4,258
I was given several (9) of these when a friend retired from his tool making job sometime ago.
I took a photo of the tool holder so that I could make one later ....err, make that yesterday, and this is what I ended up with.
the photo of the one I copied shows serrations across the plate which are obviously to ensure the blade doesnt move once clamped.
Not having an easy way of putting in serrations I resorted to using 10mm grub screws that can be tightened after the plate is firmly done up.
The flat bar is pinned with hardened dowels and welded for good luck... bitofputtyherewilldisguisethecrapyweld...lol still in the learning stages of welding
13th Mar 2017, 06:10 PM #2Diamond Member
- Mar 2014
- South of Adelaide
- 1,227
I threw one of those parting tool holders in the scrap bin not long ago, would have given it to you if i knew you needed one. Worst parting off tool i have ever used. The holder you made looks good.
13th Mar 2017, 08:28 PM #3Most Valued Member
- 4,258
Bugga.
13th Mar 2017, 11:42 PM #4
Nice one!
I consider them the best parting tools I've ever used..... I even made a miniature replica of mine to fit the little lathe....
What do you dislike about them snapatap?Cheers, Joe
14th Mar 2017, 04:18 AM #5
Hi Joe,
Nice holder, I'm curious, why didn't you go for a rear style one ?Best Regards:
14th Mar 2017, 07:49 AM #6Most Valued Member
- 4,258
14th Mar 2017, 09:59 AM #7Member: Blue and white apron brigade
Good work and that welding looks fine to me.
One thing I find when parting is I often seem to find I'm parting close to the chuck and luckily my parting tools have very little on the side between the parting tool and the chuck. Maybe using CS hex screws for the Mark II version ?
14th Mar 2017, 10:09 AM #8Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,898
Although the pictures show tipped blades, the inclined holder also works well with HSS parting blades with a tapered cross section.
As the blade is narrower at the bottom, tilting it forward means it is also narrower behind the cutting edge.
So, there's no need to grind the desirable side clearance, as it's already there.
These are what I was taught to use at a TAFE evening course.
Jordan
14th Mar 2017, 01:12 PM #9Cheers, Joe
15th Mar 2017, 04:37 AM #10
Hi Joe,
Thanks for that note. I did wonder if that was the reason why when I thought about it later. Anyway it still looks goodBest Regards:
3rd Apr 2017, 07:38 PM #11Senior Member
- May 2015
- Richmond
- 214
sold pending pickup NSW - Newcastle- 5/8" sprung parting tool holder + blades
By bollie7 in forum METALWORK - Machinery, Equipment, MARKETReplies: 0Last Post: 19th Feb 2017, 04:18 PM -
Parting Tool Holder
By Pete F in forum METALWORK PROJECTSReplies: 5Last Post: 2nd Aug 2016, 10:09 PM -
Older style Angled Parting tool holder ?
By gawdelpus in forum METALWORK GENERALReplies: 16Last Post: 3rd Apr 2014, 11:31 AM -
Has anyone got plans for the reverse parting off tool holder
By bitza500 in forum THE HERCUS AREAReplies: 15Last Post: 15th Oct 2009, 08:51 PM -
Quick Change Parting Tool Holder
By wannabe in forum METALWORK GENERALReplies: 9Last Post: 18th Apr 2009, 10:28 PM
