Results 1 to 13 of 13
Thread: Home made collet draw tube
27th Dec 2015, 02:27 AM #1Member
- Jul 2009
- perth
- 67
I needed a simple collet draw tube to use on a hercus 260 for use with W20 collets.
I made it from tube to avail of the advantages of the hollow centre.
The brazing of parts enabled it to be made of scrap pieces and during the process there was surprisingly little distortion of the tube.
The internal thread of 1 2/3 mm pitch or 1.667 mm was simply achieved by placing a 30 tooth stud gear and setting the quick change box to cut a 1 mm thread.
The collet adaptor to go in the spindle was made to suit the collet dimensions.
A nice piece of she oak was selected to go on the end to facilitate hand tightening.
P/S The steering wheel is very useful for cutting large threads up to shoulders and eliminates brown pants moments
Cheers Tom
27th Dec 2015, 06:45 AM #2Philomath in training
- 6,559
The Sheoak knob certainly looks classy but if it were my workshop with all the dirty, graphite and grease it would soon get confused with a piece of ebony.
If you are using W20 collets, does that mean you are a Schaublin owner as well?
27th Dec 2015, 03:08 PM #3Member
- Jul 2009
- perth
- 67
I wish I was a schaublin owner ( maybe one day)
The W20 collets came with an old Simonet lathe a lesser known Swiss machine of 90 mm centre height but still a quality item.
I wish my pictures were the right way up!!
Tom.
image.jpgLast edited by Christos; 31st Dec 2015 at 06:12 PM. Reason: Fixing the photos to be right way up.
27th Dec 2015, 04:50 PM #4Banned
- Aug 2015
- QLD
- 735
27th Dec 2015, 05:38 PM #5
27th Dec 2015, 05:57 PM #6Golden Member
- Mar 2009
- 54
- 825
Great job Tom, I love the steering wheel hand crank, that's an idea I reckon I'll be stealing.
Greg.
6th Jan 2016, 08:27 AM #7Most Valued Member
- Oct 2007
- 3,112
7th Jan 2016, 01:05 AM #8Member
- Jul 2009
- perth
- 67
I'm afraid not Pete
I copied an original one and it didn't seem to have the internal buttress thread just a 60 deg standard metric profile (collets definitely have buttress)
Don't quite understand how it will wear being forced up against a thread of different profile?
tom
7th Jan 2016, 06:46 AM #9Philomath in training
- 6,559
Simply that if the thread profiles are the same, the load is theoretically spread across the whole face of the thread but if they are different the force becomes a line contact, increasing the local pressure on the contact surfaces. This in turn could lead to galling, distortion and things coming loose. Both threads should be the same type although whether it is a major concern in real terms depends on a number of factors - I suspect that there are millions of Whitworth bolts out there assembled with UNC nuts for example.
For something like a collet there are high loads on the thread so it would be better if the threads matched. My concerns would be either the threads binding up or alternately it coming loose while being used.
7th Jan 2016, 08:03 PM #10Most Valued Member
- Oct 2007
- 3,112
Yes, unremarkably I agree with Michael on this one. Indeed the designers went to the effort to specify a buttress thread (a weird angle pairing at that too) instead of a V profile, because of their concerns about thread strength in torsion.
I haven't had a need to cut any Schaublin internal threads, but have done externals, and once the gearing is sorted they're no more difficult than a conventional thread and are cut the same way. The difficulty is in fact in grinding the tool, and even that isn't exactly difficult, just fiddly. IIRC I set it up on the surface grinder in a ball vice and digital angle gauge and was able to grind the tool quite accurately. However the same accuracy could probably be achieved by various other means and a creative mind.
19th Jan 2016, 04:13 AM #11
I used an old washing machine tub pulley when I made mine. Very useful gadget, particularly when setting up to thread something especially if its an internal one.
24th Jan 2016, 02:48 AM #12
I found some pictures of mine.
The brass collar prevents putting it to far up the spindle.Best Regards:
26th Jan 2016, 01:18 AM #13Member
- Jul 2009
- perth
- 67
Very well done
i love the way our little machines turn us into masters of improvision
Home made shaper
By bwal74 in forum EBAY, GUMTREE, and other off forum sales sitesReplies: 0Last Post: 19th Jul 2014, 05:49 PM -
Another home made lathe
By nadroj in forum METALWORK GENERALReplies: 16Last Post: 28th Apr 2013, 11:48 AM -
Home made hydraulic tube bender
By 19brendan81 in forum METALWORK GENERALReplies: 14Last Post: 31st May 2011, 04:04 PM -
Hercus 260 collet draw bar
By jamie_c in forum THE HERCUS AREAReplies: 1Last Post: 20th Nov 2009, 04:30 PM -
Home made anvil
By Brickie in forum METALWORK GENERALReplies: 4Last Post: 3rd Jan 2008, 12:53 PM
