Results 1 to 1 of 1
Thread: Tyre Depth Gauge DRO
26th Dec 2015, 06:14 PM #1Most Valued Member
This is just an adaptation of the one Rob (Xanadu on YouTube) made. I buried three 10x10 magnets in pockets in the aluminium block. This makes it easier to remove fine swarf. It also drastically reduces the pull of the magnets, so I drilled the holes to within about 1.5mm of the face of the aluminium.
The probe has a 6mm diameter tip that has three 3mm diameter x 1.5mm long magnets glued into the end. These provide enough pull to keep the probe attached to the saddle, but not so much that they rip the guts out of the depth gauge if you go beyond it's full travel.
A cap screw prevents damage to the depth gauge when the saddle is wound too far to the right.
Tyre Hammer
By Swarfmaker1 in forum THE SMITHYReplies: 3Last Post: 17th Jun 2015, 08:43 AM -
Mitutoyo depth gauge and other items
By Burner in forum EBAY, GUMTREE, and other off forum sales sitesReplies: 0Last Post: 1st Aug 2014, 12:09 AM -
Tyre size query.
By pinedeck in forum TRAILERS & OTHER FABRICATED STUFFReplies: 3Last Post: 26th Feb 2014, 10:36 AM -
tyre to leaf spring clearance
By danielhobby in forum TRAILERS & OTHER FABRICATED STUFFReplies: 8Last Post: 21st Jun 2011, 09:29 PM -
Mitutoyo Dial Depth Gauge - Resetting Zero
By Anorak Bob in forum METALWORK GENERALReplies: 3Last Post: 2nd May 2011, 01:22 PM
