Results 1 to 9 of 9
    Mar 2009
    49
    637
    Default Deutsches Museum - Munich
    Today we visited the Deutsches Museum in Munich and all I can say is wow, this is exactly what a museum should be. My son and I spent more than six hours wandering around and still only got to see about half of it. Here's a few photos but nothing can do justice to seeing it in person, and this is just a small fraction of the engines, pumps and other machines in the mechanical power section.
    A genuine 1 horse power motor.
    1847 10hp Half beam steam engine.
    1839 30hp Oscillating cylinder steam engine.
    1865 160hp Poppet valve steam engine, note random human to indicate scale.
    1835 20hp Beam engine.
    1863 12hp Double side valve steam engine, I've never seen one of these.
    Greg.
    Mar 2009
    49
    637
    Here's some photos of the lineshaft workshop in the machine tools section. Apologies for the picture quality, the lighting in the line shaft workshop was at a level to simulate kero lamps so not the most conducive to taking photos.
    View of part of the lineshaft workshop.
    Baby planer.
    Die filer.
    Large hand powered pillar drill.
    Serious column (camelback) drill.
    Unusual two way vice.
    Large fly press.
    Hand planer.
    Greg.
    Mar 2009
    49
    637
    Some more photos of the lineshaft workshop
    Rasp making machine.
    Bevel gear planer.
    Flywheel lathe.
    Portable drilling machine, what they used in the days before Sluggers.
    Greg.
    Feb 2009
    moonbi nsw Aus
    64
    297
    Great photos!!!! The design and detail to be pleasing to the eye is so good. In our "do it/want it now" way of doing things seeing machines that are ornate is great
    Just do it!
    Kind regards Rod
    Mar 2009
    49
    637
    Some photos of a few of the more contemporary machines:
    Maho MH300P NC/manual mill
    Hurth. V10B mill
    Deckel FP2NC (I think) mill.
    Deckel FP1 mill.
    Flott drill press with see through covers so the innards are visible.
    Heyligenstaedt lathe, again with perspex covers so you can see the inner workings.
    Waldrich Coburg planer, note the two heads allowing two surfaces to be machined simultaneously.
    That's about it for now, posting photos using an iPad is a pain in the bum. Apologies for some of the photos appearing to be cropped, I'm not that bad of a photographer, it's just how they come up when they're rotated on the iPad in order to get them to display correctly.
    Greg.
    Sep 2011
    Ballarat
    60
    3,042
    Quote Originally Posted by kwijibo99 View Post
    Greg.
    Hi Greg
    many many thanks for the pics, loving every one of them.
    I'll try and explain the double valve .
    The outside valve rod is connected to two adjustable blocks that ride on the outside of the main valve. Hidden from view is an adjusting handle that either brings the two block closer together or further apart This set up is called 'Meyer expansion gear' or a 'Meyer overriding valve'.
    A good way to explain this is that in a car you accelerate to get up to speed then back off on the accelerator and cruise at speed with little throttle.
    In this type of steam engine once the engine is up to speed using full 'admission' of steam which is about 70% of each stroke you adjust the (hidden) handle and wind the blocks closer together which only allows steam to enter the cylinder for about 30% of its stroke saving steam consumption. Boiler attendants love them.
    On some engines the governor controls these blocks. And if you have been to Sovereign Hill you would have seen two engines like this and a third one with a slightly different setup to do the same thing.
    I can post some pics if you would like to see the blocks.
    I'll also apologise for this post but I can't help myself, probably withdrawals from doing this all day long anymore.
    Phil
    Nov 2010
    Gippsland Victoria
    639
    That first shot of the lineshaft workshop was stunning -
    Bill
    Mar 2009
    49
    637
    Thanks fellas.
    Phil, thanks for the explanation, your info is always valuable. There was a skeletonised model of the Meyer valve which could be operated by hand to show how it worked, I guess I must have seen them before it's just not something that I picked up on until it was highlighted.
    Greg.
    Jun 2007
    Ipswich QLD
    63
    1,626
    Thanks for all the photos
  1. Black Country Museum !
    By BaronJ in forum ELECTRICALS
    Last Post: 14th Aug 2018, 07:43 AM
  2. Bradford Industrial Museum.
    By BaronJ in forum METALWORK GENERAL
    Last Post: 26th Feb 2018, 08:06 AM
  3. The Centricator - A Co-Axial Indicator from Munich
    Last Post: 28th Aug 2012, 01:32 PM
  4. More machine art from Munich
    Last Post: 26th Oct 2011, 07:53 AM
