Page 4 of 4 FirstFirst 1234
Results 46 to 54 of 54
  1. #46
    Oct 2016
    129
    Finish off the DRO set up, the x axis is not reading property when moving the x axis hand wheel. Have to see if i can find a user manual for the mitutoyo DRO. Also fabricated a chip guard for the mill.
    Resize of IMG_6809.jpgResize of IMG_6810.jpgResize of IMG_6811.jpgResize of IMG_6812.jpg
  2. #47
    Aug 2015
    Melbourne, Australia
    407
    Re those last pics of the machine getting back together. Well done. Doesn't it feel good to the stage that you have more back on the machine than scattered about the workshop!
    It sure is starting to look like a mill again. Re the dog teeth - geeez. I have 'head rattle' on the BP - but not too bad. The cause is the dog teeth. Fortunately, they can be bought. Not very cheap at about $700 AUD but good you can still get em!
    edit: I forgot to ask - what is the material you used for the chip guard and where did you get it?
  3. #48
    Oct 2016
    129
    Quote Originally Posted by StrayAlien View Post
    Thanks Greg,
    Yeah it sue does feel good to get everything back together and have more room in the workshop. Can't wait to use the mill for the first time, need to start work on my trike project and will need a lot of machining done with the mill and lathe. Good for you that you got your mill up and running How does it compere to the chinese mill ? Sounds like you have the same problem that i have with the dog teeth, your lucky you can get a replacement part. I have to get one made up and will cost over $1,000 so will make my own part i have a lathe and a milling machine so why not make the part just collecting some tooling that i will need. As for the chip guard material i went to clark rubber.
    Mark.
  4. #49
    Oct 2016
    129
    I had to shorten the quill spring as the new one was a bit to long, but work out well.
    Resize of IMG_6820.jpgResize of IMG_6816.jpgResize of IMG_6818.jpgResize of IMG_6819.jpg
  5. #50
    Oct 2016
    129
    Bolted on the top housing on the mill head, just waiting for my local engineering shop to weld up a crack on the motor mount and she ready for a test run.
    Resize of IMG_6833.jpgResize of IMG_6834.jpgResize of IMG_6837.jpgResize of IMG_6838.jpgResize of IMG_6839.jpg
  6. #51
    Oct 2016
    129
    After two days i pulled apart the top part of the mill head to see how the oil flow went, all good, oil has drain onto the tapered bearings. So i think a bit more time the oil will make it's way down to all the bearings.
  7. #52
    Oct 2016
    129
    So i pre oiled all the bearings before assembly of the mill head, got the motor installed and did a test run all good for the speeds i have for now until i make up the new dog clutch gears. So i did a test on the suds pumps that's working and did try out the power table feeds, then about 2 minutes running it stop What the hell it was working just fine and now it stop, could not change speeds it felt like something has jam up inside the gearbox. So drain the oil out and remove the front cover and i got a big surprise i left a rag inside So pulled out the rag and had to remove the gearbox from the saddle, to hard to fit the front cover back on in the vertical position all good now So i can now say that this project is finish well almost still have some more work to do, but i can use the mill now to machine parts.
    Resize of IMG_6849.JPGResize of IMG_6850.jpgResize of IMG_6853.JPGResize of IMG_6854.JPGResize of IMG_6851.JPGResize of IMG_6852.JPG
  8. #53
    Aug 2015
    407
    Very well done mate. Despite the rag incident you must be very happy. Thumbs up.
  9. #54
    Oct 2016
    129
    Thanks mate, Yeah happy at the moment still need to use it a bit more and see what problems will show up, still a lot more work to do on the mill. Since that rag incident i want to make those plastic shift levers out of brass will need to do some research on that project, will have the keg furnace finish soon so can do the casting myself. Also would like to add a power feed for the knee as well and of course make up new dog clutch gears. Did make up my first part on the mill for the quill power feed gearbox all good
    Mark.
  1. Okuma LP Lathe Clean Up and Repair
    By Turbine Builder in forum ANTIQUE AND VINTAGE MACHINERY
    Last Post: 4th May 2017, 06:41 PM
  2. Replies: 2
    Last Post: 17th Apr 2017, 07:29 PM
  3. Clean Metal
    By YarrD in forum METALWORK GENERAL
    Last Post: 3rd Apr 2011, 04:01 PM
  4. Rambaudi Mill Information
    By dreinoga in forum METALWORK GENERAL
    Last Post: 2nd Mar 2011, 10:25 AM
