Page 2 of 2 FirstFirst 12
Results 16 to 18 of 18
  1. #16
    Oct 2016
    64
    Finish the top coat on the main body of the mill. I had a problem when rolling out the final coat, the foam roller was leaving small air bubbles on some of the areas on the mill. so i gave it a light sanding with 800 grit sandpaper and use some fine automotive cut and polish.
  2. #17
    Oct 2016
    64
    Done the first coat of primer on the knee. Went out and got one of those airless spray guns, WOW it did the job really well and took me 5 minutes to paint. I will get most of the parts degrease and prep for painting.
    Resize of IMG_6611.jpgResize of IMG_6616.jpgResize of IMG_6612.jpgResize of IMG_6613.jpgResize of IMG_6614.jpgResize of IMG_6615.jpg
  3. #18
    Oct 2016
    64
    I finally got the knee painted and the other parts and fitted back on the main body of the mill, i replace the two thrust bearings with new ones and found the shaft is bent will machine a new one once the mill is up and running. I'll get some new Flush Grease Zerk Nipple Fittings as i can not push oil through some of them. Next is cleaning and panting the drive motor and saddle and gearbox.
    Resize of IMG_6628.jpgResize of IMG_6629.jpgResize of IMG_6630.jpgResize of IMG_6631.jpgResize of IMG_6632.jpgResize of IMG_6633.jpg
  1. Okuma LP Lathe Clean Up and Repair
    By Turbine Builder in forum ANTIQUE AND VINTAGE MACHINERY
    Last Post: 4th May 2017, 06:41 PM
  2. Replies: 2
    Last Post: 17th Apr 2017, 07:29 PM
  3. Clean Metal
    By YarrD in forum METALWORK GENERAL
    Last Post: 3rd Apr 2011, 04:01 PM
  4. Rambaudi Mill Information
    By dreinoga in forum METALWORK GENERAL
    Last Post: 2nd Mar 2011, 10:25 AM
