Results 1 to 4 of 4
Thread: heavy load
    Jul 2008
    near Warragul, Victoria
    3,726
    Default heavy load
    This I think is a Cincinnati Milling machine sitting in a blitz truck during WW2 in Australia. You would think the mill would be more suited to factory production, seems a waste to see it in such a precarious setup in the truck. I believe its a machinery body truck, I see two vises and a small lathe. They would have had a generator trailer towed . The poor blitz would struggle with that lot.
    Oct 2008
    Cairns, Q
    666
    Thanks for the WW2 mobile workshop photo. The mill certainly seems big in proportion to the other machine tools.
    Here's a WW1 version for comparison - no mill, but a bigger lathe, which appears to be set up for either treadle or power operation, and a good sized drill press and grinder. The narrow solid tyres on the truck must have made it easy to bog the vehicle in muddy or sandy conditions. I wonder if the generator was separate, or driven from the truck engine?
    https://www.awm.gov.au/collection/B02069/
    Frank
    Jul 2008
    3,726
    Default Ww1
    Trucks or lorries were widely used in WW1 . A guy down at Paynesville in East Gippsland has a WW1 Albion truck restored.
    Here is a example of the dedication these restorers go to: These guys fabricate all sorts of parts , with much turning and fitting involved.
    WW1 Thornycroft restoration - Pre WW2 vehicles - HMVF - Historic Military Vehicles Forum
    Sep 2008
    Petone, NZ
    68
    76
    Quote Originally Posted by franco View Post
    ...but a bigger lathe, which appears to be set up for either treadle or power operation, and a good sized drill press and grinder...
    I can't speak for the other equipment, but the blacksmiths post drill (centre of photo) looks to be hand powered only (although flat belt "loose & fast" pulleys were an option for most models).
    Thanks for posting.
    Cheers, Vann.
    Gatherer of rusty planes tools...
  1. bearing pre load
    Last Post: 4th Nov 2011, 03:52 PM
  2. Trailer load for registration
    By dowse in forum TRAILERS & OTHER FABRICATED STUFF
    Last Post: 13th Jul 2011, 07:54 AM
  3. axle load capacity?
    By danielhobby in forum TRAILERS & OTHER FABRICATED STUFF
    Last Post: 3rd Nov 2010, 06:35 PM
