Results 1 to 6 of 6
    Dec 2007
    1,628
    Default Eye bender Build
    I started building a new eye bender on Monday unfortunately unforeseen unfortunate events have & will prevent me from finishing for a while.
    Adjustment pin holes for the clamping bar. 1/2" drilled on the Denbigh. Drilled 2up back to back combined thickness 20mm
    Mock assembly
    1" SHS to be bolted to the base so it can be held in the vice. My previous one had angle iron but some of the old post vices are too worn to hold well on such a thin section.
    Drilling the main arm for the die pins.
    I timed the actual drill time, set up and alignment not included. It takes the Denbigh 4:31.28 minutes to put a through hole in. So if you add up all those holes and multiply by 4 1/2 min it takes a while.
    May 2011
    Murray Bridge S Aust.
    5,945
    Thanks for the pics. Look forward to seeing it in operation.
    Jul 2008
    near Warragul, Victoria
    3,718
    what is a eye bender ?
    Dec 2007
    1,628
    An eye bender is used to bend solid rod or bar into round loops.
    Good for doing eyes on the end of hooks etc.
    Dec 2007
    1,628
    Been going stir crazy, So a friend came around to supervise me in the shed today and make sure I didn't do too much. I did some drilling, tapping and welding and made the bender look more like a bender than a pile of metal bits.
    The vide block bolted on.
    The body and arm are all finished.
    Now just the clamp lever to go.
    A few hrs in the shed and I'm exhausted just laying on the couch trying not to fall a sleep.
    Aug 2010
    Horsham Victoria
    113
    Good to have friend's that can help
  1. Roller Bender Build
    Last Post: 9th Mar 2017, 08:37 AM
  2. WTB: flat bar bender
    By meadow street in forum METALWORK GENERAL
    Last Post: 16th Aug 2015, 05:50 PM
  3. help me build a basic flat build bed trailer for my kayaks
    By gros21 in forum TRAILERS & OTHER FABRICATED STUFF
    Last Post: 13th Oct 2011, 08:47 AM
  4. Trailer - to build or not to build
    By motegi in forum TRAILERS & OTHER FABRICATED STUFF
    Last Post: 6th May 2009, 03:07 PM
  5. Rod bender
    By Andy Mac in forum METALWORK GENERAL
    Last Post: 4th Aug 2008, 10:47 PM
