Results 1 to 4 of 4
Thread: Antique Drill Chuck
5th Apr 2017, 07:46 PM #1
Antique Drill Chuck
I got this lovely chuck for my post drill today.
J.H.Westcotts Little Giant Improved
Patented Mar.17th 1874 & Apr.14th 1885
By Westcott Chuck Co. Oneida USA
I pulled it apart and cleaned it, put some fresh oil on it. Really interesting is all the parts are stamped with branding and other details.
Need to make up a chuck key for it. The ends of the T handle are meant to be a bladed screw driver and a smaller square key.…..Live a Quiet Life & Work with your Hands
6th Apr 2017, 01:22 AM #2Most Valued Member
- 5,943
Thanks for that Dale, a very interesting concept, almost like a 4 jaw chuck, but with 2 screws!!!!!
6th Apr 2017, 09:06 AM #3
Not quite Kryn,
It more like two self centring jaws, each of the jaws are Vee blocks. The Vee blocks are cut in a way that the interlock to close.
The two additional screws are just screws, when you use a large dia. Shank drill you screw these in last to add extra support. The screws or independent jaws are stepped down so the jaw end is actually quite small and wouldn't have a lot of holding power.
Slightly different version from the net. I think this is the small size of the original. Mine is the IMPROVED.…..Live a Quiet Life & Work with your Hands
7th Apr 2017, 08:56 AM #4Golden Member
- Cairns, Q
- 666
Dale,
Did you come across this thread? Maybe a bit more information here.
J H Westcott's Little Giant Double Grip Chuck help requested
Frank.
Drill Chuck Run Out
By Chris Parks in forum METALWORK GENERALReplies: 14Last Post: 31st Dec 2016, 04:15 PM -
Drill Chuck for O Mill
By bwal74 in forum THE HERCUS AREAReplies: 7Last Post: 17th Jun 2015, 06:56 PM -
Drill Chuck
By Oldneweng in forum METALWORK GENERALReplies: 14Last Post: 24th Sep 2013, 05:10 PM -
Antique McPherson drill press
By morrisman in forum METALWORK GENERALReplies: 13Last Post: 1st Jan 2012, 07:37 PM -
rohm drill chuck
By tanii51 in forum METALWORK GENERALReplies: 7Last Post: 25th Apr 2010, 11:23 PM
