Results 1 to 5 of 5
Thread: woodfast universal woodworker
5th Jan 2017, 01:04 PM #1
I stated this project last year, so have some time to do some work on it. I got this machine from my local scapy $50 as you can see it is missing a lot of parts. I'll have to modify it to work as a bench saw only, the bad part is one side of the casting has some cracks that will need to be repaired. I will remove the planer part on the shaft as to reduce any stress on that side of the metal casting that will be welded.
MC1966-Woodworking.jpgResize of IMG_5714.jpgResize of IMG_5712.jpgResize of IMG_5713.jpgResize of IMG_5741.jpgResize of IMG_5739.jpgResize of IMG_5740.jpgResize of IMG_5778.jpgResize of IMG_5779.jpgResize of IMG_5782.jpgResize of IMG_5780.jpgResize of IMG_5781.jpg
5th Jan 2017, 01:34 PM #2Most Valued Member
- Jul 2016
- 35
- 1,522
do you think you will braze or nickel weld the cracks? the casting does look quite thin in that fillet.
5th Jan 2017, 02:34 PM #3New Member
- Oct 2013
- Perth, Australia
- 4
Subbed. Love the old Woodfast machines, just picked up a 10" jointer last week that I've started restoring.
5th Jan 2017, 06:02 PM #4
5th Jan 2017, 06:15 PM #5
Yeah the Woodfast machine are well built, this one is very heavy that's why i grab it. The heavy the machine the better Some more photos here,tack weld 1/4 inch nuts to screw on one of the covers and will make up the other cover. The machine will sit on a steel box platform with caster wheels.
Resize of Resize of IMG_0049.jpgResize of Resize of IMG_0046.jpgResize of Resize of IMG_0047.jpgResize of Resize of IMG_0048.jpg
Universal machine
By morrisman in forum METALWORK GENERALReplies: 11Last Post: 11th May 2012, 12:39 AM -
ub-100 universal bender
By green shed in forum METALWORK GENERALReplies: 2Last Post: 17th Oct 2007, 12:11 AM
