Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
  1. #16
    Dec 2007
    1,628
    Hi Greg,
    I'm pretty shattered about knocking it off the bench an busting it. If you think you can fix it for me I'd be indebted to you. How does the Baffle actually work, it it just to stop water boiling and splashing out of the hopper?
    Would you happen to know what thread is in the brass fuel needle and fuel uptake? I'd like to run a tap through before putting them back.
  2. #17
    Mar 2009
    54
    825
    G'day Dale,
    Don't be too hard on yourself, you haven't really worked on old machinery until you've broken or damaged an irreplaceable part.
    The baffle's primary purpose is to prevent a sudden drop in temperature when you add cold water to the hopper to replace that lost through evaporation.
    Cooling in these engines works on a thermosiphon principal. The hot water from the head expands through the upper port into the top of the hopper, this draws water into the head from the bottom of the hopper through the lower port. The water in the hopper is hotter at the top and sinks to the bottom as it cools and the cycle repeats.
    If you pour a bucket of cold water into the hopper it will immediately sink to the bottom because it's more dense than the hot water. This cold water will then get drawn into the head rapidly cooling it which is not ideal, particularly for a kero engine. The pot shape of the baffle with a hole in the bottom allows the cold water to mix gradually thus reducing the drop in temperature. As you said, it also helps reduce the amount of water sloshing out the top.
    Sorry I've got no idea what thread is on the needle or pickup tube, if I had to guess I'd say 3/8 Brass (BSB) but that would just be wild speculation. Unless the thread is damaged I wouldn't bother, just use a good non hardening sealant (Permatex Aviation Form-A-Gasket Sealant Liquid - No. 3, 59mL - Supercheap Auto) on the pickup tube and you should be right.
    Give us a yell when you can drop off the busted baffle, you can bring it to me at work in Rowville if that's any easier.
    Greg.
  3. #18
    near Rockhampton
    6,217
    Quote Originally Posted by DSEL74 View Post
    Hi Greg,
    That is a POP fix (piece of )
    Either braze it or high nickel content cast iron stick rods. So simple I could do it upside down while blindfolded with both hands tied behind my back. Well, maybe not quite like that .
    If you stick weld it, preheat it first.
  4. #19
    May 2011
    Murray Bridge S Aust.
    5,958
    One thing I didn't see mentioned, was that DON'T wrap the hand and thumb around the handle, unless you'd like a broken thumb. Something I got told when I was about 17.
  1. keep it safe guys
    By the fabricator in forum METALWORK GENERAL
    Last Post: 3rd Jan 2011, 03:34 PM
  2. Great Guys
    By Caliban in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACK
    Last Post: 27th Oct 2003, 10:22 PM
