Page 62 of 64 FirstFirst ... 12525758596061626364 LastLast
Results 916 to 930 of 948
Thread: Whisperings
  1. #916
    6,480
    Hi Phil,
    Thanks for the pictures and explanations. nicely done.
    I wonder if one of those rubber strap type jar screw lid removers would have worked to remove that shell ?
  2. #917
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,561
    The trouble with those rubber strap things is that they stretch and so for tight items, don't work all that well (at least the ones I've used when trying not to damage the chrome finish on tapware). I did use a Ridgid brand cloth strap wrench that worked better (less stretch) but my favourite is a Vice-grip chain wrench. Phil's solution is probably the best as the wall thickness on the lubricator may not be much and spreading the load would be critical to avoid more disappointment...
    Phil, I have 5/16" BSF taps and dies in one of my sets if you need one.
  3. #918
    Sep 2011
    Ballarat
    65
    3,103
    Hi Michael,
    I'll see how we go sourcing one locally first but I don't like my chances. I could always single point it seeing as there is one to do.
    Many thanks...as usual.
    Phil
  4. #919
    Sep 2011
    Ballarat
    65
    3,103
    I know I still have the making of the levers but I couldn't resist and made a short clip of the pump in action.
    Lovely to see it run as slow as it did.
    Phil
    https://www.youtube.com/watch?v=DnbCI5y9pH8
  5. #920
    May 2011
    Murray Bridge S Aust.
    5,959
    Thanks for the video clip, a fascinating piece of machinery. I don't know what it is about old stuff like that, that is so mesmerizing.
  6. #921
    Sep 2011
    Ballarat
    65
    3,103
    Hi Kryn
    it's even better standing next to it while it actually pumps water into the boilers.
    Phil
  7. #922
    Sep 2011
    Ballarat
    65
    3,103
    I finally found a couple of the missing pics. I located them in what is called a 'cloud'.
    All I can say is it must have been a very cloudy day when I saved them as I somehow have amassed several 'clouds'.
    Due to some errors (surprisingly not mine this time), I will be machining two more spools and one more lever but I suppose 'practise makes perfect'
    Phil
    20170815_103516 copy.jpg 20170815_103808 copy.jpg 20170815_103714 copy.jpg IMG_9171 copy.JPG IMG_9178 copy.JPG IMG_9182 copy.JPG IMG_9230 copy.JPG IMG_9266 copy.JPG IMG_9274 copy.JPG 20170531_115530.jpg 20170614_155056.jpg 20170614_154958.jpg
  8. #923
    Oct 2011
    59
    6,561
    Gee Phil - the shaft in that last picture looks a bit beat up, and those glands could do with a tidy up too... ()
  9. #924
    Sep 2011
    Ballarat
    65
    3,103
    ahhh gees, there's one in every village.
  10. #925
    Sep 2011
    Ballarat
    65
    3,103
    Another little aside job came up during all this and that was the needle out of one of the drip feed lubricators broke off.
    This one was fun fun fun
    Phil
    Phoenix7 copy.jpg 20170720_085544 copy.jpg 20170720_084933 copy.jpg 20170720_091008 copy.jpg 20170720_094832 copy.jpg 20170720_103950 copy.jpg 20170720_110118 copy.jpg 20170720_114237 copy.jpg 20170720_123700 copy.jpg
  11. #926
    May 2011
    5,959
    [QUOTE=Steamwhisperer;1925808] Phil IMG_9182 copy.JPG QUOTE]
    Hi Phil, this might sound a DUMB question. But if a disc of say 75 mm diameter were placed in between the 2 points and then eyeballed to being level.
    Would that be dead on centre? Similar to a rule being placed on a round bar for drilling in the centre of the bar.
    Just asking as I'm still learning this type of work.
  12. #927
    Sep 2011
    Ballarat
    65
    3,103
    [QUOTE=KBs PensNmore;1925819]
    Quote Originally Posted by Steamwhisperer View Post
    It would Kryn but both points would have to be in pretty good condition and possibly the disc hardened so you didn't end up with a plethora of dots.
    Something to think about anyway.
    Phil
  13. #928
    Sep 2011
    Ballarat
    65
    3,103
    Now I know I'm going to get flamed for this but seeing as sometimes there is discussion about the virtues of Loctite. I thought I would show how stuff was held together etc. before Loctite was around.
    Bearings and bushes that I have to renew are machined according to the 'Limits Fits and Tolerances' table and still work well.
    Flame away and I will try to come back with a suitable answer.
    Phil
    IMG_9155 copy.JPG IMG_9157 copy.jpg IMG_9158 copy.JPG IMG_9160 copy.JPG IMG_9164 copy.JPG IMG_9166 copy.jpg IMG_9168 copy.jpg
  14. #929
    Apr 2009
    Ballina N.S.W.
    644
    Hi Phil,
    Thanks for the great photos. In your job you would be in all sorts of trouble if some of those shafts were locited, as you have to do maitainance every so often the old proven ways of fixing are more suitable. You can get away with a lot larger tolerances with loctite and it saves time on production jobs, time is money these days.
    Bob
  15. #930
    Sep 2011
    Ballarat
    65
    3,103
    Quote Originally Posted by krisfarm View Post
    Hi Phil,
    Bob
    Good point Bob, I think I may have been working in the past too long.
    Phil
