Page 61 of 63 FirstFirst ... 11515657585960616263 LastLast
Results 901 to 915 of 944
Thread: Whisperings
  1. #901
    May 2011
    Murray Bridge S Aust.
    65
    2,875
    Glad to see you back on here. Nice one Phil, a bit of bog and a coat of paint, an no one will be any the wise except you, and everyone else who reads this forum.
  2. #902
    North Yorkshire UK
    1,471
    Hi Phil,
    Nice work. Thanks for the notes on the pictures. Those weights remind me of the ones used on fly presses.
    BaronJ.
  3. #903
    Sep 2011
    Ballarat
    59
    2,933
    Hi Phil,
    Nope, nothing like the ball on a fly press Baron. Fly press balls are for walking into and cracking your skull on.
    These ones are well out of the way.
  4. #904
    Sep 2011
    Ballarat
    59
    2,933
    The eccentric for the valve gear needed a fitting so I could adapt it to the new wick feeders.
    There is a decided lack of pics but sometimes I forget.
    Any questions just ask.
    IMG_0023.JPG IMG_9709.JPG IMG_9712.JPG IMG_9752.JPG IMG_9755.JPG IMG_9761.JPG DSCN0076 copy.JPG
  5. #905
    Sep 2011
    Ballarat
    59
    2,933
    About 2 1/2 years ago we had some fatal issues with the Worthington pump used to pump water into the boilers. The rocker arms that actuate the slide valves had some cracks in them so it was decided to make some new ones along with new spools and for good luck I made some new piston rings for the water end.
    We had some new rocker arms profile cut out of some 20mm thick plate which left some machining to make them look (a bit) like the originals. More on them later.
    Here is how the new piston rings were made.
    Phil
    20170725_154952.jpg 20170725_164020.jpg 20170727_085209.jpg 20170727_085656.jpg 20170727_114228.jpg 20170727_114845.jpg 20170727_141002.jpg 20170727_141007.jpg 20170727_141225.jpg 20170727_153504.jpg 20170727_153512.jpg 20170731_124400 copy.jpg 20170731_125050 copy.jpg 20170731_134925 copy.jpg
  6. #906
    Apr 2009
    Ballina N.S.W.
    537
    Phil,
    A great bit of planning that job, nice clear pictures and nice maching. I see you still use a few of the old Whitworth threaded bolts.
    Bob
  7. #907
    Sep 2011
    Ballarat
    59
    2,933
    Quote Originally Posted by krisfarm View Post
    Phil,
    Bob
    Thanks Bob, it's pretty much all Whitworth as opposed to British Standard Whitworth which makes the challenge a little bit more interesting.
    Luckily I have a book that has all the specs on Whitworth nuts and bolts.
    Phil
  8. #908
    Sep 2011
    Ballarat
    59
    2,933
    Next up was the spools though I seem to have misplaced some of the pics of the setup for machining the offset hole.
    Phil
    20170713_123547 copy.jpg 20170713_141559 copy.jpg 20170717_113839 copy.jpg 20170717_130758 copy.jpg 20170717_140028 copy.jpg 20170717_161801 copy.jpg 20170720_151503 copy.jpg 20170720_154219 copy.jpg
  9. #909
    Oct 2011
    Burnie/ Adelaide
    52
    4,476
    Quote Originally Posted by Steamwhisperer View Post
    I machined the recess to depth using the dial indicator as this machine has metric collars with imperial screws
    No thoughts of making new ones then? I would have thought short of a DRO that would be a more sensible way of having the machine.
    I do like seeing the set-ups that people use to make parts. I'll need to check my RT now to see what the taper is and whether I have an ER chuck to suit.
  10. #910
    Nov 2008
    Perth WA
    65
    5,811
    Superb presentation Phil and a hell of a job as usual! And plenty of rainy day tricks to save among your numerous setups.
    Thank you
    Bob
  11. #911
    Sep 2011
    Ballarat
    59
    2,933
    Hi Michael,
    You couldn't even begin to imagine how high that is on my priority list.
    The centre on that rotary table is #2 Morse so I have made a short drawbar just to make sure it doesn't pop out.
    Phil
  12. #912
    Sep 2011
    Ballarat
    59
    2,933
    Thank you
    Bob
    Many thanks Bob, high praise indeed.
    Phil
  13. #913
    North Yorkshire UK
    1,471
    Hi Phil,
    Super work ! Thanks for the pictures and explanations, I've learnt a lot from those.
    I do have one question though... When you are drilling through a collar, as you show, how do you stop the two parts from locking together where the drill breaks through into the core? I usually have to wrench the two bits apart and hope that it is not too badly scored.
    BaronJ.
  14. #914
    Sep 2011
    Ballarat
    59
    2,933
    Hi Phil,
    Hi Baron
    Thanks Baron, when drilling through like I did and the drill passes into the stub you have to make sure that your tolerances are pretty tight as any gap will allow a burr and aren't they fun things.
    I had to bore the collar to suit the piston rod on the pump so it was a relatvely easy task to turn the stub to a (borderline) transition fit.
    It's easier if you use some emery cloth but I never seem to be able to get a decent (roundish) journal when I do. I thought cylindrically grinding was a bit over the top.
    A firm fit is the key though not always possible.
    Phil
  15. #915
    Sep 2011
    Ballarat
    59
    2,933
    Here is another job on the pump, well the lubricator on the pump. Inside the lubricator body is a copper riser pipe that snapped off (I don't wish to discuss how ).
    To replace this pipe the body has to be separated from the base. To do this without damaging the body I needed a...something, to assist in it's removal.
    The thread on the copper pipe is of course 5/16" BSF, the one die I 'don't' have. .
    No pics of the separation but it worked incredibly well and the boss is in the process of a full set of engineering drawings...as you do.
    Phil
    Lubricator.jpg 20170814_084830 copy.jpg 20170815_103432 copy.jpg 20170815_110044 copy.jpg 20170815_111904 copy.jpg 20170815_151857 copy.jpg 20170815_133026 copy.jpg
