Results 1 to 6 of 6
    Mar 2005
    Sinny, Straya
    64
    18
    Talking Hi from north west Sydney
    Hi all,
    Well this is a surprise! I went to register and found that I had already registered back in 2005 for the woodwork forums, but then moved on to other things (mortgage repayments mostly). Now, 13 years later and in semi retirement, I've bought my first metal lathe (Sieg SC4) and mill (Sieg SX2.7) and am looking forward to learning some new skills.
    Andrew.
    May 2013
    Rockhampton, QLD
    68
    456
    Welcome Andrew.
    Nov 2010
    Gippsland Victoria
    733
    G'day Andrew,
    A Lathe and a Mill right from the start - you dont muck around - well done - you'll be able to do heaps of interesting things with those. I found the Workshop Practice books and Spareys book "The Amateurs Lathe" to be pretty good reading to get an initial appreciation of some of the differences between holding and cutting wood vs holding and cutting metal.
    Bill
    Jan 2011
    Sydney, Australia
    12
    Welcome to the group hope you enjoy your stay, it is a great place to be.
    Barry,
    Blacktown.
    Mar 2005
    Sinny, Straya
    64
    18
    Thanks Bill, I'll see if I can find those books.
    I've watched an awful lot of Youtube videos so far, and thought I was up to speed, but it's amazing the difference between just watching and actually doing. I've broken so many cutters and nearly crashed the lathe once. To help avoid a repeat I'm about to replace the control panel touch switches with paddle switches so that I can operate the lathe by feel instead of having to look at the control panel ... just waiting for parts to arrive.
    Andrew.
    Jan 2004
    Mackay North Qld
    6,446
    Can I suggest that you start a thread in the GENERAL Metalwork section.?
    Tell us what sort of cutters-HSS or inserts and the material you are cutting - the type of steel and diameter and spindle RPM used.
    There are a few guys here with Seig lathes so they will be in a good position to help you.
    There is a lot of general stuff to learn and I am confident that members will pitch in an offer advice as to why you are breaking cutters.
    You will be making chips soon I am sure!
  1. Machinist in West Melbourne.
    By lewisc in forum METALWORK GENERAL
    Last Post: 8th Nov 2017, 04:06 PM
  2. BCLM, Dudley, West Midlands, UK
    By BaronJ in forum METALWORK GENERAL
    Last Post: 31st Oct 2017, 10:05 PM
  3. Replies: 7
    Last Post: 31st May 2011, 03:17 PM
  4. Heads Up on Course in Melbourne's West
    By billrule in forum METALWORK GENERAL
    Last Post: 10th Feb 2009, 12:45 PM
