Results 1 to 3 of 3
    34
    1,080
    Default Starting at the bottom again
    Hi All,
    Some of you will know me from WWF.
    I'm starting a Fitting and Turning apprenticeship with a gear manufacturer in 6 weeks and really looking forward to it.
    Can anyone suggest some reading material? I have a copy of Fitting and Machining from TAFE Publications which I'm finding really good, what else is worth looking for to start out?
    Also, what tools should I be looking at? I have already picked up 25mm, 50mm and 75mm Starrett mics (there's a nice 0-150mm set on ebay with standards, but I didn't see it until after I bought the 3) as well as various squares, bevels and levels - all Starrett as well. I do want a nice set of every day calipers as I don't really think using a master set on the shop floor is a great idea, the question being Starrett, Mitutoyo or TESA? Should I be going digital for everything possible, or stick to analog?
    Look forward to learning lots here and hopefully contributing down the track.
    Jul 2016
    35
    1,522
    Good news! I find that calipers both get dropped and abused i definitely go for mitutoyo, nothing fancier.
    If it's the gear shop I think it is in the south east you are welcome to come by my little shop near moorabbin airport for a chat sometime.
    Regards Ralph
    34
    1,080
    Thanks, I definitely will once I've started. It sounds like I'll be around the corner from you at the big gear shop just past the airport
  1. Starting out with AC/DC TIG
    By RustyArc in forum WELDING
    Last Post: 10th Nov 2016, 12:56 PM
  2. starting thread problem.
    By JDarvall in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACK
    Last Post: 2nd Dec 2008, 06:54 PM
  3. Starting a cut
    By Mathuranatha in forum WELDING
    Last Post: 3rd Jul 2008, 07:50 PM
  4. Starting and ending a weld
    By phelum in forum WELDING
    Last Post: 12th Mar 2008, 10:36 PM
