Results 1 to 6 of 6
Thread: Silver Soldering,
31st Jan 2017, 04:54 PM #1New Member
- Jan 2017
- Lorne victoria
- 3
Silver Soldering,
I have recently become addicted to making model sailing yachts, that is ones that are R/C controlled and do sail. I have found that there are often tiny brass parts that I need to fabricate from sheet rod or tube and solder . I have tried various soldering irons and a small butane fired torch but the results have been rather hit and miss. I recently purchased a plumbers Propane torch which certainly produces more heat but is rather big and clumsy for my work, I suspect that I need a jewellery makers torch that is smaller lighter and more controllable.
Can any one advise me on a suitable type and what gas and or oxygen is required and the name of a supplier/s. I have seen some that are getting close to $ 300.00 which is a bit more than I wish to spend. I have also recently read about a soldering pick which seems to be a helpful tool, so far every time I have tried to solder parts together I am frustrated by not having enough hands to direct flame, hold part and apply solder. I am also confused about hard and soft solders. Any advise would be really welcome.
31st Jan 2017, 06:48 PM #2Philomath in training
- 6,563
G'day Tony - welcome to the forum. Suggest you have a look at this thread
//metalworkforums.com/f310/t199...copper-jewelry
in the jewellery section as they talk a little about soldering there and the gear to use
31st Jan 2017, 10:30 PM #3New Member
- Jan 2017
- Lorne victoria
- 3
1st Feb 2017, 01:11 AM #4Most Valued Member
Hi Tony and Welcome to a top Forum. For your Silver Soldering torch I suggest a small torch that runs on butane and is refillable from a larger can. I have one that I purchased from Jaycar that I use for repairing bandsaw blades.
Cat no. TS1660 and the cost, an expensive $39.95
1st Feb 2017, 11:41 AM #5New Member
- Jan 2017
- Lorne victoria
- 3
Thanks Kryn,
I will check it out.
I also quite like "the one who dies with most toys wins"
1st Feb 2017, 01:16 PM #6Senior Member
- May 2013
- Rockhampton, QLD
- 68
- 456
Welcome to the forum Tony.
Ross
Silver soldering question
By phaser in forum METALWORK GENERALReplies: 31Last Post: 7th Apr 2016, 11:22 AM -
Jigs for Silver Soldering
By electrosteam in forum METALWORK GENERALReplies: 5Last Post: 6th Jan 2014, 09:50 AM -
Cleaning Brass after Silver Soldering
By Garry Edwards in forum METALWORK GENERALReplies: 7Last Post: 16th Jun 2012, 09:06 AM -
silver soldering
By Rossluck in forum METALWORK GENERALReplies: 14Last Post: 25th Sep 2009, 09:01 PM -
Silver Soldering
By John Richards in forum METALWORK GENERALReplies: 15Last Post: 13th Jul 2008, 08:38 PM
