Results 1 to 5 of 5
Thread: G`Day from Perth
28th Dec 2016, 03:24 PM #1New Member
- Dec 2016
- 6
G`Day from Perth
G`Day all,
Nice to meet you all. I`ve only found this forum very recently after purchasing a Sieg C6 lathe secondhand in Perth & seeking out information. Congratulations on your site from what i`ve read so far there`s a wealth of valuable & varied information here.
Regards,
Jeremy
29th Dec 2016, 01:42 PM #2Senior Member
- May 2013
- Rockhampton, QLD
- 68
- 455
Welcome to the forum Jeremy.
Ross
29th Dec 2016, 04:43 PM #3Senior Member
- Oct 2009
- Upwey VIC
- 187
Jeremy,
Welcome to the forum.
There are a couple of guys here that have a C6 lathe, including myself.
Andrew.
30th Dec 2016, 05:22 PM #4New Member
- Dec 2016
- 6
Cheers Ross
30th Dec 2016, 05:34 PM #5New Member
- Dec 2016
- 6
Cool Andrew, last time i used a lathe was high school nearly 40 years ago but looking forward to repairing a few items around the house & embarking on some projects. I haven`t turned anything yet I wanted to go through the lathe first with lubrication etc and a general check over & I have rectified a few anomalies along the way, the main one I found was a tight spot in the cross feed, it turned out to be the adjustment on the cross feed hand wheel with that small set screw on the tightening nut it`s extremely sensitive.
I`ve also had to remove the Splash shield a couple of times & you need to remove the four tiny screws on the cover at the back which covers the electrics, funnily enough they`re exactly the same size & thread as computer case thumb screws - that was my first mod.
Antonov An-225 visiting Perth
By GuzziJohn in forum GENERAL DISCUSSION / OFF TOPICReplies: 9Last Post: 13th Jul 2016, 06:37 PM -
Mazak course in Perth, looking for people
By Lanza in forum METALWORK GENERALReplies: 0Last Post: 17th Dec 2012, 07:08 PM -
J&E Ledger Perth
By rodm in forum METALWORK GENERALReplies: 8Last Post: 27th Jul 2012, 02:32 AM -
Metal in Perth
By derekcohen in forum METALWORK GENERALReplies: 7Last Post: 7th Apr 2007, 08:50 PM -
Milling Machines in Perth
By Sterob in forum METALWORK GENERALReplies: 5Last Post: 29th Sep 2006, 11:03 PM
