Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
Thread: Windsor engine
  1. #16
    Dec 2015
    202
    Cool thread.
    Cant help with the engine search.....will be after one myself i think !
    I have a mate up Ballarat way who has a nice litel Clevor motor (windsor dart block with local clevland aluminum heads on it.
    chris gt40 - Page 5 - GT40s.com
  2. #17
    Oct 2010
    melbourne, laverton
    1,910
    [QUOTE=Ryan in Melbour;1909590]Cool thread.
    very nice how much work is there in fitting the Cleveland heads to the Windsor block?
  3. #18
    Dec 2015
    202
    azz, i think he said the heads were made locally?
    i have no idea when it comes to engines.
    google is giving me this though
    Hybrid Technology - Muscle Mustang And Fast Fords March 2006 - CHI Cylinder Head Innovations
    Contact Us - CHI Cylinder Head Innovations
  4. #19
    Oct 2009
    Upwey VIC
    187
    [QUOTE=azzrock;1909593]
    Quote Originally Posted by Ryan in Melbour View Post
    Cool thread.
    I don't know about anything recent, but in the '70s there were a few things that needed to be done:
    1. Water passage outlets to the deck side of the heads needed to be sealed shut and new outlets to the intake manifold side needed to be opened.
    2. New pushrods needed to be made up due to the different deck height etc.
    3. A Boss 302 intake manifold was required.
    4. Pistons needed to be machined to provide valve clearance due to the different valve location in the heads.
    5. Pushrod guide plates/hardened pushrods were needed (I think) due to the different pushrod angles with the shorter deck on the Windsor block.
    6 Special extractors were required as the Cleveland was wider across the exhaust ports, and the Windsor ports were a different shape/position.
    Probably a lot of other details I've missed, as I haven't had much to do with this stuff for 30 years.
    Andrew.
  5. #20
    Dec 2015
    202
    got message back from Chris
    this is where the heads come from
    SCM Engine Developments - Home
  6. #21
    Oct 2010
    melbourne, laverton
    1,910
    Cool I might start a tread in the auto section
  7. #22
    Nov 2012
    tasmania
    2
    Quote Originally Posted by azzrock View Post
    Attachment 363385It for this project. A 69 ford pv.
    a Gm based car would make it cheaper.
    As as for the diff between the Cleveland and Windsor . The Windsor replaced the Cleveland.
    Incorrect the windsor in Australia came before the cleveland and had a reputation for throwing rods it was replaced by the cleveland in the early seventies the cleveland had big square looking heads and was much wider than the old windsor. Ford axed the v8 in the falcon and when it came back they used the windsor which was obviously better than the old windsor. Ps the clevelands had a weakness also in that when they are highly stressed the used to split bores so if buying a 2nd hnd clevo check the bore size to make sure it hasnt been bored as this weakens the cyls even more. The splits in the bore tend to start half way down vertically and when they reach the thicker metal at the bottom of the waterjacket they turn horizontally.
  1. Goggo Engine
    By Goggomobile in forum AUTO RESTORATION
    Last Post: 1st Jul 2016, 09:03 PM
  2. Engine Turning
    By Hercus71 in forum METALWORK GENERAL
    Last Post: 4th Dec 2014, 09:16 AM
  3. Engine turned ?
    Last Post: 16th Apr 2013, 01:42 PM
  4. Search engine
    By Grahame Collins in forum METALWORK GENERAL
    Last Post: 21st Dec 2012, 06:57 PM
  5. Tiny V12 engine
    By Chief Tiff in forum METALWORK GENERAL
    Last Post: 16th Sep 2012, 10:04 PM
