Page 1 of 2 12 LastLast
Results 1 to 15 of 24
    Aug 2018
    20
    Default 1961 Spit screen Kombi
    Hi everyone,
    i came accross this forum on a mission to learn about a lathe I recently purchased.
    As part of a restoration build of my 61 VW panel van, I found myself in extremely new waters, and have been learning slowly about metal shaping, welding and repairing the un reparable.
    I recently got back into the project and thought I would share my new approach.
    cheers,
    joe
    Nov 2007
    Near Rockhampton
    270
    Hi Joe. I will be watching your progress with interest. I know how one's commitment to a project comes and goes over time.
    Hopefully work will be starting on my new shed within the month and then it's back into some of my neglected projects.
    John
    Aug 2006
    1,106
    Will also my watching this, should be an interesting project When is the next video coming?
    Aug 2018
    20
    Here is my second video instalment where I’m learning to build a wooden buck to help build the engin lid door skin.
    Aug 2018
    20
    Moving along, in this video I’m trying out shaping metal with an English wheel, and a shrinker.
    Aug 2006
    1,106
    Any more updates to this?
    Aug 2018
    20
    Default DIY Metal folder
    Here is my attempt at building a metal folder.
    May 2011
    Murray Bridge S Aust.
    5,958
    Thanks for that Joe, I liked the magnetic clamp idea.
    Dec 2007
    Sydney
    398
    Joe
    Nice idea on the magnet, a mates got a magnabend fabricated but can’t afford the copper windings for it, this may help him out.
    By the way Grays have a Yard Clearing auction at Mittagong with a few Kombi bits in it.
    H.
    Jimcracks for the rich and/or wealthy. (aka GKB '88)
    Nov 2004
    Bungama SA
    52
    960
    Where have I been... awesome project.
    The bender is pretty cool, cant believe you dont have many views on YT its good viewing!
    Aug 2018
    20
    Thanks everyone.
    I’v spent a bit of time researching the use of bead rollers, and how I can use that to create better panels for my project.
    Here is my first attempt.
    Nov 2004
    Bungama SA
    52
    960
    Gday Joe great vid once again, I purchased one of those bead rollers and half way through the 1st bead on some 1mm material the top wheel started loosing traction and kept spinning... I though it was me doing a too heavier run(was only 1/3 of a turn of the depth adjuster thingo at a time).
    So I though Id change the large dies to some thing smaller thats when I found the bottom wheel freewheeling
    Its back at H&Fs getting fixed ATM, what I found is the lower shaft not engaging in the offset gearbox... some numbskull who assembled it at the factory didnt place the spline key fully into its slot and proceeded to seat it home with a hammer! (the only touch up paint on the whole machine is on that gearbox which too me says its been hit as no other touched up paint chips are evident on the machine and theres a number of paint chips on it...)
    AS I removed the gear box it was easy to see as the key was chewed up and the slot was blown out at the side rear, obviously the key was half in half out just enough to pass QC.
    So it will need a new lower shaft and key... well it better have as I will not except a bodgey fix it job creating a weak point on a brand new $2000 machine
    So please remove your lower offset gear box and make sure that tiny undersized key and slot has been assembled properly... might save the head aches later on down the track
    Aug 2018
    20
    Default Metal to wood
    As the winter chill begins to freeze my...... garage, I’ve been spending quite a bit of time insulating and paneling the inside.
    technically, this has meant a shift from working with steel, to working with wood for a while.
    Apart from the never ending dust, I’ve really enjoyed this, and the inside is coming along nicely.
    I did get to weld some steel shelves, and had fun creating curved edges with angle iron. I’ll post some pics and add a video soon.
    Oh, I may have gone overboard with a split system heater/cooler wifi control, but hey, who doesn’t want to keep their workshop at a comfortable stable temp?
    Aug 2018
    20
  15. #15
    Oct 2008
    N.W.Tasmania
    1,407
    Great thread Joe, and very nice work. Thanks for taking us along
  1. Army apprentice 1961
    By morrisman in forum ANTIQUE AND VINTAGE MACHINERY
    Last Post: 14th Oct 2015, 11:18 PM
  2. Home made Spit
    By timbo123 in forum METALWORK GENERAL
    Last Post: 20th Jan 2009, 12:20 PM
  3. Full screen/Part screen
    By Big Shed in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACK
    Last Post: 16th Jan 2007, 12:28 AM
