Results 1 to 3 of 3
    May 2011
    Murray Bridge S Aust.
    5,959
    Default Different repair of a Cast Iron Head
    Saw an interesting process on a British show, Car SOS, on Friday Night 3rd Feb. around midnight. A cylinder head had a crack in the water jacket on top of the head, where there is a raised section like a pipe that goes to the radiator, that had the crack in it.
    How it was done was called a cold welding process, that entailed cutting out the cracked section and replacing it with another piece of cast metal, this was hammered in, then cut across the joins, clips inserted and a special type of screw inserted.
    The whole repair section was then filed flush, to look very similar to the finished head.
    Tried to find a You Tube Video of it but all entailed a welder.
    Aug 2010
    Near Bendigo, Victoria, AUS
    72
    3,105
    I think its called "stitching".
    Here is a training video of one of the many commercial processes:
    https://www.youtube.com/watch?v=Pq0wfU4ZaKk
    Cheers, Joe
    Dec 2005
    South Australia
    1,658
    Yep it's called metal stitching it is one of art's that is disappearing I have seen cylinder heads and blocks run for a life time after being repaired in this way, can be performed in place in many cases with disassembly
  1. Cast Iron Repair
    By Scott in forum WELDING
    Last Post: 18th Sep 2013, 01:42 PM
  2. Cast iron pot repair
    By lordnelson in forum METALWORK GENERAL
    Last Post: 12th Oct 2011, 08:36 PM
  3. Cast iron table repair
    Last Post: 22nd Jun 2011, 07:18 PM
  4. Cast Iron Weld Repair
    By Woodlee in forum WELDING
    Last Post: 22nd Jun 2008, 10:13 PM
  5. Repair of Broken Cast Iron
    By Grahame Collins in forum METALWORK GENERAL
    Last Post: 11th Feb 2006, 11:35 PM
