Results 1 to 6 of 6
28th Feb 2016, 10:21 AM #1Member
- Dec 2014
- Goldcoast
- 78
Polishing and Restoring Aluminium Bits On a Restoration
Hi all
strangely enough I've got a lot of aluminium strips to clean and polish. I'll remove very carefully. Polish I guess and coat with something.
Ive never done this before. Any tips . I've got some mops.
28th Feb 2016, 11:35 AM #2Member: Blue and white apron brigade
Avoid alway polishing in the same direction otherwise it can streak.
So something like passes at 0º and the 90º at a minimum.
if you want to get it schmick do one at 45º as well and alternate directions as well.
If the pieces are rough and knock about they might need a bit of sanding.
I find giving oxidised pieces a run over with a fine scotchbrite wheel speeds up the process.
28th Feb 2016, 02:43 PM #3
India Ink
Several years ago, NASA found that India ink is best for polishing Al. Improves fuel consumption, I guess.
JoeOf course truth is stranger than fiction.
Fiction has to make sense. - Mark Twain
28th Feb 2016, 04:33 PM #4Most Valued Member
Hi Randal
Once you've got them nice and polished, powder coating them in clear does the trick.
28th Feb 2016, 07:25 PM #5
If using a bench mounted grinder for butting, just keep them supported with something if they are long and thin, and keep in mind they can be pulled out of your hands by the buff with a moment's inattention and thin edges work exactly like dull but effective knives, so make sure you pay attention to any likely grab spots!!
Otherwise, Supercheap has some good drill mounted scotchbrite and cotton polishing bobs for a few dollars.
2nd Mar 2016, 09:46 PM #6Member
- Dec 2014
- Goldcoast
- 78
Thanks everyone. Some great tips. I'll keep you posted.
Randal
router bits in lathe to mill aluminium - youtube video
By steamingbill in forum METALWORK GENERALReplies: 3Last Post: 29th Oct 2013, 06:55 PM -
Satin polishing aluminium
By WortGames in forum METALWORK GENERALReplies: 18Last Post: 16th Jan 2011, 08:57 PM -
polishing the shiny bits
By tanii51 in forum METALWORK GENERALReplies: 2Last Post: 3rd Oct 2010, 10:04 PM -
Polishing the shiny bits
By neksmerj in forum THE HERCUS AREAReplies: 11Last Post: 2nd Dec 2008, 05:05 PM
