Results 1 to 9 of 9
    Jan 2016
    Gosford
    63
    173
    Default Bargain Morse Taper Imperial Drill Bits in Sydney
    If you can bid on this in the next 10 hours and then collect from Campbelltown tomorrow or Friday this could be a bargain. The current bid price wouldn't even pay for 1 of the larger drill bits and while the listing ad says 20 there are more than that plus a machine vice included as well. Listing doesn't say what Morse Taper but the drill sizes range from 1/2" to 1 1/2" in 1/64" increments. a couple missing but looks to be duplicates of the 1 1/2".
    http://www.graysonline.com/lot/0166-...ch-to?spr=true
    7,183
    Quote Originally Posted by glivo View Post
    Can't imagine they will stay at that bid for long.
    The MT sizes are usually determined by each drill diameter.
    Jan 2016
    Gosford
    63
    173
    Bidding usually goes up at the last moment I agree BobL, but you just never know. Some of the items in other listings have had bid activity already long before the end time. The 3 Hercus 260 lathes I was looking at have gone from under $300 2 days ago to up around the mid $500 mark now with 6 hours to go.
    I guess it just depends on the item, how many people have use for them and also how many people don't bother because they think the bids will go up. As long as you have your own upper limit and stick to it is the rule for any auction. I've seen some pretty bizarre results at auctions on both ends of the scale.
    7,183
    I'd bid if I was able to pick them up.
    Jan 2016
    Gosford
    63
    173
    Same here. That's why I posted about them here otherwise I'd have kept mum about it. I can't have them but somebody else on the forum might be able to get them. I'm about to leave home to head to Newcastle to view the little Advance lathe I'm considering and then I'll be in Maitland till Friday afternoon.
    Oct 2015
    melbourne
    473
    $259+ 22%=about $320
    Russ
    Jan 2016
    Gosford
    63
    173
    Did you win them russ57 or is that the end price? I didn't see the end of the auction. Still for 30 odd large and good quality drill bits plus a machine vice it is pretty good buying if you have a use for them.
    Dec 2007
    Sydney
    396
    That machine vice was a seperate lot.
    146 the drills were 166.
    Usual grays.
    I wish who ever takes the photos knew what is of interest, that little bandsaw looked ok, had a countershaft but without a rear photo you couldn’t tell if had a gearbox or not.
    H.
    Jimcracks for the rich and/or wealthy. (aka GKB '88)
    Jan 2016
    Gosford
    63
    173
    OK. Well that was a bit misleading. Even so, the drills were still pretty good buying for whoever got them at that price.
  1. 4 1/2 morse taper sleeve
    By dodge at4 in forum WANTED TO BUY
    Last Post: 3rd Mar 2017, 03:28 PM
  2. Morse Taper 1-3?
    By goodwoody in forum METALWORK GENERAL
    Last Post: 25th Nov 2014, 06:52 AM
  3. Morse taper drill recommendations
    By jmebgo in forum METALWORK GENERAL
    Last Post: 18th Feb 2014, 12:47 AM
  4. Fluid cooled Morse Tapper bits
    By wheelinround in forum METALWORK GENERAL
    Last Post: 9th Nov 2013, 11:11 AM
  5. Releasing morse taper
    By jvdv in forum METALWORK GENERAL
    Last Post: 24th Oct 2007, 04:01 PM
