Results 886 to 900 of 1090
26th Mar 2018, 12:35 AM #886Golden Member
- Jul 2011
- 837
Hercus #1 Tool and cutter grinder, https://www.gumtree.com.au/s-ad/elth...der/1178526098
26th Mar 2018, 12:36 AM #887Golden Member
- Jul 2011
- 837
26th Mar 2018, 02:34 PM #888Most Valued Member
- 5,943
If that's all you're getting,tell him he's Dreaming!!! Doesn't show or tell of any accessories??
31st Mar 2018, 01:15 PM #889Diamond Member
- Sydney, NSW
- 1,249
Really big vice:
https://www.gumtree.com.au/s-ad/berk...ill/1179703289
31st Mar 2018, 05:28 PM #890
19th Apr 2018, 10:01 PM #891Most Valued Member
- 5,943
Incase someone's looking for a Slotter $300 or best offer.
https://www.ebay.com.au/itm/183184181604?ul_noapp=trueTo grow old is mandatory, growing up is optional.
26th Apr 2018, 12:14 PM #892Senior Member
- Apr 2013
- Toowoomba Qld
- 401
Lathe chucks anyone ?
https://www.gumtree.com.au/s-ad/chel...cks/1181539665
Cheltenham VIC
Large number of 3 and 4 jaw old lahe chucks from $50 each.
Few other items from the same seller
https://www.gumtree.com.au/s-seller/gary/1018658744
3rd May 2018, 11:25 AM #893Most Valued Member
- 2,651
I was down there yesterday. The chucks are fairly well picked over - mostly larger ones (200mm and up) left.
Sounded like the big radial arm drills were going to the scrappie.
There's still a heap of lathe toolholders and various machine tools. Much more than is listed on Gumtree and all will be going one way or another. Either someone buys them or they will be scrapped.
8th May 2018, 06:08 PM #894Golden Member
- Jul 2011
- 837
Waldown NH Surprise!
A Waldown NH is up for auction at Evans and Clarke. I went down and took the covers of and this is what I found. A 4 pole instead of a 2 pole motor and V belts instead of flat belts. It certainly wont give anywhere near the 12000rpm of the original.
8th May 2018, 10:13 PM #895Philomath in training
- 6,541
I believe that there were actually two versions of the high speed Waldown made - one that went to 30k rpm and one that went to 12k.
8th May 2018, 11:50 PM #896
Michael is right about the two versions. But they both had 2-pole motors and managed 12000 & 18000rpm - both had flat belt drives.
So this is either a 'special' - which Waldown did - or an owner modification.
My NH is a factory special, with fixed head and rise and fall table (probably bench drill stock).
Cheers, JoeCheers, Joe
9th May 2018, 12:11 AM #897Golden Member
- Jul 2011
- 837
I did neglect to mention the speeds plate had the same 4 speeds listed as mine 3000, 6000, 9000, 12000 so should have had the same pulley ratios. The welding I neglected to photograph around the hub of spindle pulley makes it almost certainly an owner modification. Why however I can only guess. I hope whoever wins isn't expecting an unmodified NH.
Cheers, Eric.
9th May 2018, 08:50 PM #898Most Valued Member
- 5,943
The reason for the different motor, could possibly be that the original motor died and the replacement was what was at hand?
13th May 2018, 09:49 PM #899Golden Member
- Jul 2011
- 837
Probably but why change the pulleys? If you kept those the top speed would be a respectable 6000rpm. Anyway someone paid $290 plus buyers premium etc. I hope they knew what they were buying.
21st May 2018, 04:12 PM #900Senior Member
- Apr 2013
- Toowoomba Qld
- 401
Have not been checking gumtree often but had a look today and found a few that might be of interest to others
https://www.gumtree.com.au/s-ad/shep...ton/1184080813
PUBLIC AUCTION- Shepparton
SPECIALIZED WORKSHOP EQUIPMENT, SPECIALIZED WORKSHOP TOOLS, WORKSHOP TOOLS, OFFICE FURNITURE & SUNDRIES Friday 15th June at 10:30am on site A/C Carmody Engineering 56-58 Annerley Avenue, Shepparton
https://www.gumtree.com.au/s-seller/...2946367/date/1
This Seller has a few items listed, noted as VERY CHEAP. If they know the actual value or not would depend on how accurate this is...
Located in Ballarat City Wendouree
https://www.gumtree.com.au/s-ad/wend...ine/1183870141
Free delivery Melb /Sydney King Rich KR-V2000 milling machine
https://www.gumtree.com.au/s-ad/wend...eap/1184469605
Milling machine parkson n1
https://www.gumtree.com.au/s-ad/wend...ast/1184469750
Bandsaw steelfast
eBay (and other auctions) Metalwork Stuff
By ubeaut in forum EBAY, GUMTREE, and other off forum sales sitesReplies: 3411Last Post: 14th Oct 2014, 10:29 PM -
Who really wins Ebay auctions
By Terry B in forum METALWORK GENERALReplies: 140Last Post: 6th Sep 2010, 09:54 PM
