Page 3 of 3 FirstFirst 123
Results 31 to 32 of 32
Thread: Hot Bluing
  1. #31
    Jan 2016
    Wodonga Vic
    33
    336
    I've read up on a few bluing formulas and most called for potassium nitrate, some used ammonium nitrate because of availability but the process had to be done outdoors due to ammonia fumes, any nitrate salt will do the job, and I'm sure sodium nitrate will work but potassium nitrate, being non hygroscopic and non fuming, is more stable in the formula compared to sodium/ammonium nitrate.
    Hope this helps
  2. #32
    May 2010
    Pilbara
    93
    so once the hot tank has been made, and the solution used, is there any special storage requirements?
    I recall we had a hot bluing tank in SHS, and the teacher just kept a lid on it most of the year, but I never knew if there was fumes causing corrosion, or if the mix had to be dumped each year, etc.
    I imagine the salts would need to be renewed/ added to over time, but if the tank was only used once every 3-6 months, is there any storage considerations needed?
    FYI - been a while since I bought potassium nitrate - but the hydroponics people seem to have good quality fertilizers at reasonable prices...
  1. More metal bluing
    Last Post: 25th Aug 2015, 10:23 PM
  2. Bluing a tapered shaft
    By jack620 in forum METALWORK GENERAL
    Last Post: 9th Apr 2013, 07:02 PM
  3. My second attempt at steel bluing
    Last Post: 22nd Jul 2012, 01:00 PM
  4. Bluing
    Last Post: 28th Apr 2009, 10:37 PM
  5. Metal bluing solution
    By ohno in forum METALWORK GENERAL
    Last Post: 16th Dec 2006, 08:00 PM
