Results 16 to 30 of 32
Thread: Hot Bluing
17th Apr 2017, 11:58 PM #16Golden Member
- Nov 2010
- Gippsland Victoria
- 733
18th Apr 2017, 01:57 AM #17Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
Hi Bill, at that temperature it's simmering, with all the salts dissolved in the solution it doesn't "bump" like boiling water does at 100°C but it does spit small droplets around where it's being heated and release tiny caustic particles into the air that sting when they settle on skin, it's a well ventilated, covered skin and goggles affair
18th Apr 2017, 04:30 PM #18
24th Apr 2017, 08:12 PM #19
This would be a good way to make shop made tooling last longer .And look better .
18th May 2017, 07:48 PM #20
I finally got some Potassium Nitrate yesterday. It was a special order and I had to leave my ful name, address, phone and license number to get it.
Seems nobody bothers to stock it anymore because of these requirements.
I won't have a chance to try and blue anything for a week or so, but will post the results here when I do.Cheers, Joe
18th May 2017, 08:39 PM #21Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
I look forward to seeing your results Joe, it's pretty pathetic what you had to go through just to get it, lets hope counter terrorism don't swoop your house over a bag of potassium nitrate lol
18th May 2017, 10:05 PM #22Golden Member
- Nov 2010
- 733
Potassium Nitrate
I've tried too and anywhere I go they just say "No cannot get it any more - people were doing scary things with it"
When I was a kid we could get Kwikcure from the local supermarket which was then used to cure meat and was pottassium nitrate
This mob might be worth a try - am off on holidays and will try when I get back.
kno3 potassium nitrate australia
Bill
18th May 2017, 11:08 PM #23Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
15 bucks a kilo, ouch... How much did you end up paying for a bag Joe?
19th May 2017, 02:43 AM #24
I paid $71.40 for 25kg.
Happy to share, if someone else wants a couple of kg ($3 a kg + postage).Cheers, Joe
22nd May 2017, 12:56 PM #25Golden Member
- Apr 2008
- NSW
- 537
Yes they are talking about ammonium nitrate as a fertilizer however potassium nitrate is even more dangerous .
You want Sodium Nitrate not Ammonium or Potassium nitrate .The volume of a pizza of thickness 'a' and radius 'z' is given by pi z z a.
22nd May 2017, 01:05 PM #26Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
How is a Potassium ion "even more dangerous" than a sodium ion? what is your measure of danger?
22nd May 2017, 02:31 PM #27Golden Member
- Apr 2008
- NSW
- 537
Potassium nitrate is a better oxidiser if it gets heated up by a fire . On it's own it's not so bad . It is used in explosives and some rocket fuels so it is very dangerous if it gets going in a fire .
22nd May 2017, 11:03 PM #28
All three are just fertilisers and meat tenderisers.
Nothing dangerous about them at all - until you deliberately mix them with a fuel which they can oxydise. The mixtures and methods are not trivial and require research or reasonable chemistry knowledge. It is no more complex to make explosives or rocket fuel by many other means without resorting to fertiliser.....
But these were easier to control (than, say, pool chlorine.....)Cheers, Joe
23rd May 2017, 09:25 AM #29.
- 6,459
Hey Joe,
I'll put my hand up for a couple of kilos if it's still available.
Bob.
23rd May 2017, 11:21 AM #30Golden Member
- Apr 2008
- NSW
- 537
Anyway it's not Potassium nitrate you need in a bluing formula it's Sodium nitrate . To get the blotchy affect out you may need to degrease the metal before bluing it.
More metal bluing
By BobL in forum METALWORK GENERALReplies: 99Last Post: 18th Dec 2020, 09:26 AM -
My second attempt at steel bluing
By BobL in forum METALWORK GENERALReplies: 20Last Post: 4th Dec 2018, 02:25 PM -
Bluing a tapered shaft
By jack620 in forum METALWORK GENERALReplies: 20Last Post: 9th Apr 2013, 07:02 PM -
Bluing
By bollie7 in forum METALWORK GENERALReplies: 1Last Post: 28th Apr 2009, 10:37 PM -
Metal bluing solution
By ohno in forum METALWORK GENERALReplies: 28Last Post: 16th Dec 2006, 08:00 PM
