Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
  1. #16
    Aug 2016
    Sheffield, England
    60
    14
    Hi John,
    I'm currently restoring a BSA Meteor Mk5. What brand of Tung oil finish did you use on the stock?
    The meteor came with a black painted barrel and cylinder from the factory. I plan to remove that with paint stripper and blue the barrel Birchwood Casey cold blue. Apparently heating the barrel in very hot water between coats of cold blue improves the finish.
    Hi Chris
    I used a mix that's sold by a chap in Wales, THIS is the place but it looks like they've stopped selling it
    I must say, I much prefer a nice blued finish to the black enamel that Beesa ended up using
    Shall we see pics when the Meteor is finished?
    I only have one Meteor now, It's a mk1 and was nickel plated at the factory apparently, It's an early one with the serial, N268, It's .177cal..
    I've a few Mercury's that have the black paint finish, The Mercury Challenger (bottom) is blued though
    Good luck with the resto
    John
  2. #17
    Nov 2007
    melbourne australia
    2,001
    Hi John,
    I hadn't realised you are in the UK. I'll search for a stock finish locally.
    I'll certainly post a pic when I'm finished.
    cheers,
    chris
  3. #18
    Jan 2016
    Wodonga Vic
    33
    366
    What are the benefits of using Tung oil over Danish oil on a rifle stock? until now I've only used Danish oil on my rifles and just the generic stuff from the hardware store
  4. #19
    Nov 2007
    melbourne australia
    2,001
    I think Tung oil is glossier?
  5. #20
    Aug 2016
    Sheffield, England
    60
    14
    Thumbs up
    Hi
    Tung oil gives a satin finish, A truely gloss finish is attained with Tru oil although i've never used it as I don't particularly like Glassy finishes on gunstocks!!
    Here's a couple of Daystate stocks that I refinished for a chap, He was happy as larry as he tried himself using Tru oil, It stayed extremely tacky and was sticking to the fleece of the gunslips! , They also went very pale and the grain had all but disappeared
    I've never used Danish oil either!!, All i've used is the Tung oil based mixture and BLO
    John
  6. #21
    Jul 2006
    Athelstone, SA 5076
    3,501
    I have used a poly varnish and acetone mix in the past using a french polish method...its harder to do than shellac but the finish was hard and glossy smooth. Worth the stuffing around.
  1. Sand Blaster Refurb Update
    By Sterob in forum METALWORK GENERAL
    Last Post: 6th Jan 2011, 04:36 PM
