Results 1 to 7 of 7
    Jul 2007
    Narnia
    82
    Default Sako quad scope mount - machining (pic heavy)
    Finally got some time to machine a mount for my little Sako Quad .22lr
    Has 33.5 MOA of taper inbuilt, which with the scope I've chosen should leave .75 milradians in reserve still allowing me to achieve a shortish zero (You'll need to excuse my mixing standards). I intend to fit a central sight & tunnel to the Quad as well for some fullbore practise, which is the point of my building the mount the way I have to ensure a very repeatable return to zero when interchanged on and off.
    Dressing back the excess where the centre drill marks were, from the between centres setup
    Cutting a lot of material off the Opti-lock rings (High I think).
    Picked them up on ebay relatively cheaply second hand - in very tidy condition
    (...and I just cut the #### out of them)
    OD turning the large locating spigot on the underside of the modified rings, using the boring head.
    Here it is 97% completed with an M40a1 mount I happened to have stashed, thrown in for comparison.
    Machined the S/S Claws that will clamp into the dovetail, those garish hex bolts are the only M5x.8 ones I had & will be replaced with nicer dome head ones at my next convenience.
    still a little deburring to do etc - but I'll just use it for now and when I accumulate enough little projects I'll clean them all up and look to have someone Ceracoate the lot.
    WANTED: D1 - 8" Camlock either on a backing plate, or drive plate
    DECENT CONDITION, REQUIRED FOR A PROJECT - SEND ME A PM IF YOUR ABLE TO HELP
    Jul 2006
    Athelstone, SA 5076
    4,255
    very nice Brian
    the rifle looks nicer tho...but I am biased cos its a gun
    Dec 2007
    Western Australia
    11
    Nice job
    Did you do it 'because you could' or because it fulfilled a function not available in other mounts?
    "Entia non sunt multiplicanda praeter necessitatem"
    Jun 2013
    Tasmania
    257
    I have to say nice work. You sank a lot of time into that and it looks top notch.
    I've got the Sako Finnfire, also with the range stock. Lovely guns.
    Nov 2008
    Perth WA
    6,458
    Hi Glen,
    I was going to have a go about the agricultural look of the hex head bolts but given your background I'll let you get away with it.
    Stylish execution. Well done.
    BT
    Jul 2007
    Narnia
    82
    Hi all, a belated thanks for your kind comments - yeah there was definitely a bit of work involved but ultimately achieved the desired result. The taper calculations worked out to be spot on, leaving the bare minimum of elevation adjustment in reserve - can achieve the 30m zero I was after using only 1 milradian of the scopes internal elevation and everything else is up + there's additional holdover with the reticle if required (though its getting to be reaching out a fair distance with the venerable old .22lr).
    Also have replaced those bolts for bob
    Never did get around photographing it in the daylight at the time, so here's a quick update.
    Nov 2008
    Perth WA
    6,458
    Superb Glen.
    The button heads do look the part. I haven't machined much alumimium, are you using 6061?
    Bob.
  1. Viewer Scope ..gimmick or not ?
    Last Post: 29th Jan 2012, 10:02 PM
  2. Scope of LPG gas welding
    By pajeronj in forum METALWORK GENERAL
    Last Post: 30th May 2011, 10:33 AM
