Results 1 to 10 of 10
Thread: alloy casting - best finish
14th Sep 2017, 10:51 AM #1Most Valued Member
- 4,258
alloy casting - how to obtain best finish
what does one use to get a smooth finish on a alloy casting?
Is standard Petrobond that RayG refers to in casting101 ok? or is there something else/better that ensures best finsh.
I guess a finer sand would give a better smother finish than a course sand..is that right?
Just how smooth can one get a alloy casting?
Would lost foam give a smooth cast?
14th Sep 2017, 08:58 PM #2
Based on YouTube video's only, finer sand and careful packing/ramming. I am not sure about lost foam, but I suspect it would not be ideal because it is soft and that limits the rammimg. It would still depend on the sand anyway.
15th Sep 2017, 08:17 AM #3Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,039
As you surmise eskimo, using finer sand gets you a better finish on your aluminium alloy casting, petrobond sand is reputed to provide a finer finish than green sand. I use petrobond but I've never used green sand so I can't offer a comparison from personal experience. The lost foam process is just another method of sand casting.
If you look at old Australian made hot up equipment e.g. EH Holden twin carb manifolds, the surface finish on those is about the best you are going to get from sand casting.
Lots of home casting info here AlloyAvenue network
15th Sep 2017, 09:59 AM #4Senior Member
- Dec 2014
- Tasmania
- 102
Hi Eskimo, I have not tried this myself yet but in a YouTube channel I follow called 'Makercise' he was able to get a very smooth surface finish on his aluminium parts by painting his lost foam with plaster of paris. I was impressed enough that I intend to give it a shot myself.
15th Sep 2017, 11:14 AM #5
That sounds like a good idea. The trick would be to get the foam to the right pattern shape first. I was thinking of lost foam as a way to get rough shapes for later machining. That would be my main reason for casting, just to get the right size material to machine something. If only other jobs would not keep coming up taking my time.
15th Sep 2017, 02:29 PM #6Most Valued Member
- 4,258
15th Sep 2017, 02:45 PM #7Senior Member
- Dec 2014
- Tasmania
- 102
I suppose the plaster reverses the surface finish from the sand mould to the lost foam instead? I think you need to have a go and show us all how it went
16th Sep 2017, 11:11 AM #8Most Valued Member
- 4,258
24th Sep 2017, 05:28 PM #9China
- Dec 2005
- South Australia
- 1,657
You may want to investigate "Delft Clay"
25th Sep 2017, 12:06 AM #10
You could also try investment casting although the cost may be a bit high to get started initially.
Casting Tools Part 5 - Casting a part
By RayG in forum THE FOUNDRYReplies: 10Last Post: 30th Jul 2018, 12:46 PM -
Threads on finishing, finish, good finish
By steamingbill in forum METALWORK GENERALReplies: 17Last Post: 20th Jan 2014, 06:53 PM -
Alloy
By AxelVK in forum WELDINGReplies: 9Last Post: 29th Jul 2012, 12:05 AM -
Casting about for cast iron casting ideas
By Graziano in forum THE FOUNDRYReplies: 49Last Post: 1st Apr 2012, 12:05 PM -
Casting Tools Part 4 - Sand Casting Tools
By RayG in forum THE FOUNDRYReplies: 8Last Post: 9th Dec 2011, 12:03 PM
