Results 1 to 8 of 8
Thread: Gas burner
4th Apr 2017, 12:17 PM #1Senior Member
- Mar 2014
- 46
- 121
Gas burner
Gday Guys,
I am wanting to have a crack at making a mini aluminium foundry out of a old 9kg gas bottle.
I think i have worked out the refractory and general design
Would really appreciate some info re the gas burner.
I am going to use a normal bbq propane/lpg gas cylinder for the flame. My question is what necessary modifications or parts do i need to make it adequate to do the job?
Also what can I use or where can i buy the correct compound for the degassing?
many thanks Max
4th Apr 2017, 12:51 PM #2
So, which threads here and links on similar forums have you looked at so far?
Which of the several dozen designs available with great detail do you have specific questions on?
4th Apr 2017, 01:07 PM #3Senior Member
- Mar 2014
- 46
- 121
I have done a search but to be honest I know very little about whats needed. Ive seen guys using Gal pipe and fittings. Is there a commercialy available set up that will work for example
http://www.ebay.com.au/itm/like/GAS-..._qi=RTM2010745
4th Apr 2017, 06:58 PM #4Member
- Dec 2010
- Mornington Peninsula
- 97
Try GAMECO, in Auburn from memory.
4th Apr 2017, 07:27 PM #5Senior Member
- Mar 2014
- 46
- 121
Thanks Cava,
I will check it out
4th Apr 2017, 10:36 PM #6Member
- Dec 2010
- 97
4th Apr 2017, 10:40 PM #7Member
- Dec 2010
- 97
This might help.
https://www.artisansupplies.com.au/p...d-accessories/
15th Apr 2017, 03:45 AM #8Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,038
More info than you will ever need is at alloyavenue.com
Oil burner
By phaser in forum THE FOUNDRYReplies: 6Last Post: 16th Nov 2016, 10:47 AM -
Suitable Oil/Diesel Burner?
By Ueee in forum THE FOUNDRYReplies: 17Last Post: 20th Jul 2013, 07:20 PM -
burner help
By fxst in forum THE FOUNDRYReplies: 4Last Post: 21st Jun 2013, 12:36 AM -
Forced Air LPG Burner Mk2
By RayG in forum THE FOUNDRYReplies: 26Last Post: 6th Jun 2011, 12:50 AM -
Sealing gas inlets on wok burner
By R. McCarthy in forum METALWORK GENERALReplies: 16Last Post: 18th Jan 2008, 09:08 AM
