Results 1 to 14 of 14
Thread: Six kilo bronze casting
9th Mar 2017, 12:03 PM #1Senior Member
- Dec 2012
- emerald
- 161
Hi Guys, I've got a cylindrical stepped pattern that I need to have cast in brass or bronze. No coring or tricky bits, plenty of draft. According to Solidworks it will weigh in at around 6 kilograms. I need four of these made for one of my projects. Would anyone here be interested in doing this job, or alternatively could anyone suggest a commercial foundry? I'm in the eastern suburbs of Melbourne (Emerald).
Thanks for any help or suggestions.
Eric
10th Mar 2017, 05:17 AM #2Senior Member
- Jan 2012
- Hinchinbrook
- 112
I can do it. But freight will be a killer from NQ. Can I see the pattern?
Cheers Phil
10th Mar 2017, 11:00 PM #3Senior Member
- Dec 2012
- emerald
- 161
Thanks Phil, I'll get a picture taken tomorrow and check out the post cost.
Eric
11th Mar 2017, 09:39 AM #4Senior Member
- Dec 2012
- emerald
- 161
Hello Phil, Here is the pattern. I just have to clean it up and seal it. Let me know what you think.
Eric
11th Mar 2017, 09:51 PM #5Senior Member
- Jan 2012
- Hinchinbrook
- 112
Yep looks do-able. Bit hard to go off the scale of that ruler.....Based on the numbers its about 1.2 metres dia. X a bit more high! If so thats one big arsed wood screw! Can we get some draft on the upright column?
Were you able to get any postage yet?
Cheers Phil
12th Mar 2017, 08:59 AM #6Senior Member
- Dec 2012
- emerald
- 161
Hahaha. I don't know what that ruler was doing sitting there actually.
The cylinder has plenty of draft but it just doesn't show in that picture.
According to the Australia Post calculator it would cost $57.00 for two to be sent down. Ie. 12 kilograms. I'm sure I could find a better deal for the four.
Any idea on your costings?
Thanks Phil.
Eric
12th Mar 2017, 02:57 PM #7Senior Member
- Jan 2012
- Hinchinbrook
- 112
Eric,
I will have to get a price on the bronze tomorrow. Can you put some dimensions on it. Tolerances? Machined finish? If your happy with the as cast finish? Depending on these answers I think you would be looking in the region of $100 per unit (in the rough)+ material. I think last time I bought bronze it was about $8 kg. So probably minimum $600 + freight.
Online quote from TNT is $100 for 25kg package
Cheers Phil
12th Mar 2017, 07:16 PM #8Senior Member
- Dec 2012
- emerald
- 161
Hello Phil,Tolerances are no problem. There is quite a bit of machining on the units, but I can do that here. I didn't realize bronze was so pricey now. It's been around 15 years since I've had any bronze castings done. I might have to go cheap and nasty and use ally.
Eric
13th Mar 2017, 08:43 AM #9Senior Member
- Dec 2009
- 327
Eric,
there was a bell founder at Lost Trades, in 2016. I'm sure he would be more local to you (Vic?).
regs,
A.
14th Mar 2017, 08:46 AM #10Senior Member
- Dec 2012
- emerald
- 161
Thanks Andrew. It was on this weekend just gone. Pity I missed it. I was unaware of this event.
Yes I think I'll have to look for something local, the costs quickly add up. Thanks anyway Phil.
Eric
14th Mar 2017, 02:08 PM #11Most Valued Member
- Jul 2016
- 35
- 1,522
I doubt you will find a better offer than $600 for those in brass, I dont think may foundries will really want to know you for that small a run. I would dearly love to be wrong though. Even for aluminium I dont think anyone will do it for less than 600 you need to think about the time to pack the flasks, heat, pour and clean. There are so few foundries left here, you could try Alliance in carrum downs. Non Ferrous Castings, Gravity Die Castings Foundry
best of luck.
15th Mar 2017, 07:24 PM #12Senior Member
- Dec 2012
- emerald
- 161
20th Mar 2017, 12:55 PM #13
The Guy from Kyneton
.Australian Bell Pty Ltd.
Dr Anton Hasell.
Mia Mia Vic.
email address below
Australian Bell
We are travelling in Tas so I'm not on this much of late.
H.Jimcracks for the rich and/or wealthy. (aka GKB '88)
21st Mar 2017, 07:29 PM #14Senior Member
- Dec 2012
- emerald
- 161
Thanks for that contact info. I've contacted a couple of non ferrous foundries that are fairly local here. One was the one that caskwarrior (above) gave me. They both quoted me around $100 to $125 each. Pretty good really. I wouldn't expect to get it done any cheaper.
I am thinking of having a go myself. I've got a source of mixed scrap brass and I've got an old cope and drag set here under the house. I had my own backyard set up some 30 years ago, but I got rid of most of the bits and pieces long ago.
I'll start another thread with some questions regarding burners.
Eric
Recommendations - Bronze Casting Services
By Morbius in forum METALWORK GENERALReplies: 2Last Post: 8th Aug 2012, 04:41 PM -
Boring a bronze casting, actually on size.
By Graziano in forum METALWORK GENERALReplies: 25Last Post: 1st May 2012, 07:56 PM -
Casting about for cast iron casting ideas
By Graziano in forum THE FOUNDRYReplies: 49Last Post: 1st Apr 2012, 12:05 PM -
Casting Tools Part 4 - Sand Casting Tools
By RayG in forum THE FOUNDRYReplies: 8Last Post: 9th Dec 2011, 12:03 PM -
Bronze bush. What type of bronze?
By simonl in forum METALWORK GENERALReplies: 23Last Post: 5th Oct 2011, 09:40 PM
