Results 1 to 5 of 5
Thread: Foundry to cast a steel part
24th Jul 2016, 09:32 PM #1
Any of the SE Queensland members know if the foundry at Dalby is still operating?
I have a cast steel part to either fabricate or get cast.
The original is cracked from a major bingle with a bigger machine, and cant be safely repaired by welding as its a safety issue.
Fabrication will take a while as there is a quite a few machined surfaces and bores.
It is similar to the pivot assembly on a backhoe.
31st Jul 2016, 11:59 AM #2
Looking like I will have to either find a part from a machinery dismantler or spend big$ for a new part .
It seems that manufacturing in Australia is non existent , or people don't want to take on difficult tasks.
31st Jul 2016, 04:19 PM #3Most Valued Member
Mike, what's the part you're looking for, someone on here may know of a part for you???
You're right about the manufacturing industry, it seems the Govt with its RED tape and unions, don't want it here????
31st Jul 2016, 06:18 PM #4Pink 10EE owner
- 6,218
I take it Doug Slack foundry no longer exists?
31st Jul 2016, 07:59 PM #5
RC No they closed quite some time ago.
Whites in Dalby may be the closest and they will do small one off jobs .
The price from OEM is over $8k , it would take quite a long time to fabricate one and it would need stress relieving before machining as the welding will induce a lot of stress.
The machining would be about a week in between jobs , lots of bushes and bearing fits.
Casting would only require machining .
I am waiting for an email and then can decide if its worth continuing to get it cast.
Antique cast iron clamp part fixed
By aametalmaster in forum METALWORK GENERALReplies: 2Last Post: 9th Sep 2013, 07:17 PM -
Cast iron VS Cast steel lathe compound slide
By Ueee in forum METALWORK GENERALReplies: 10Last Post: 23rd Dec 2012, 11:40 PM -
welding cast iron to steel
By Knotaclue in forum WELDINGReplies: 2Last Post: 8th Oct 2010, 10:11 PM -
Removing cast handwheel from steel shaft
By billrule in forum METALWORK GENERALReplies: 14Last Post: 10th Oct 2009, 08:24 PM -
can anyone weld cast steel?
By Aaron r in forum WELDINGReplies: 2Last Post: 29th Dec 2008, 12:01 AM
