Results 1 to 10 of 10
    Oct 2006
    Armidale NSW
    52
    915
    Default Electric Furnace ... unknown control
    Hi All,
    I picked up this Gallenkamp muffle furnace the other day and have been having trouble working out what one of the controls does.
    It's the dial on the bottom right. It's graduated 1 to 100, but has no marking on it about it's function. From the little testing I have done, it seems to turn off the element when the dial is below 70.
    I have emailed Gallenkamp (Weiss actually) and because of the age of the furnace they did not have any info available.
    Anyone come across these furnaces before, or might have an idea about what this dial does?
    Thanks.
    Cheers.
    Vernon.
    Jun 2008
    Victoria, Australia
    74
    5,080
    Hi Vern,
    On similar furnaces, that is the percent on-time. Some times they are burst fired scr's.
    I'd replace the controller with a digital PID temperature controller
    Digital PID Temperature Controller MAX 40A SSR K Thermocouple Cable 0 400℃ | eBay
    Oct 2006
    Armidale NSW
    52
    915
    Thanks Ray.
    Yeah I was thinking about doing that, but I must admit I do like the look of that old school temp gauge.
    Ultimately I probably will go for the PID controller.
    Cheers.
    Vernon.
    Oct 2006
    Armidale NSW
    52
    915
    I was just looking at those cheap PID controllers and they all seem to be rated 0-400ºC.
    Now I'm not sure if that is the rating of the supplied thermocouple, or if that is the actual controlling temperature range ... most of the PID controllers I have used (it was a long time ago, mind you) would control most any temperature and the range was determined by the type of TC used.
    Cheers.
    Vernon.
    Jun 2008
    Victoria, Australia
    74
    5,080
    I like the old style temperature indicator too, that would be worth keeping.
    The temperature controller I linked to was just the first on the list, you might find a better one at a higher price, maybe even go for a programmable ramp/soak type.
    I ended up with a SET64rs ( same as JLD634) controller and a heavy gauge K type in a ceramic sheath.
    The cheaper ones might have type K thermocouples, but the packaging limits the maximum temperature.
    Mar 2013
    Mt Pleasant SA
    126
    Hi Vernon, a bit late coming in I guess. That 'unknown' dial of yours is most likely a 'simmerstat', that was the control most often linked to the old galvanometric controllers. Think of it as the ramp slope controller, it's a bimetal switch whose 'on time' is controlled by the dial position, just cycles on-off indefinitely..till the power is off.
    Oct 2006
    Armidale NSW
    52
    915
    Thanks Swarfless.
    I ended up buying a small PID controller to replace the large black dial controller and it is using the original control's thermocouple. The "simmerstat" as you call it, is still fitted but not wired in.
    The PID controller seems very accurate and works well.
    I spent a few hours, a few weeks ago, casting a lot of my scrap aluminium into muffin shaped ingots.
    I've got a project in mind, but just don't have the time to execute it just yet.
    Cheers.
    Vernon.
    Mar 2013
    Mt Pleasant SA
    126
    No sweat Vernon, I have a very similar muffle furnace to yours, gets used mainly for heat treating aluminium & steel. Since the thermal inertia of the furnace itself is the most significant factor my simmerstat is always set at 100%, in other words I might as well short it out. I've been meaning to get a PID controller for over 30 years now, but then I've only had one 'overshoot' disaster in all that time. Guess I've got to know the old controller. You won't regret the PID, set & forget! Well after it's tuned itself to your furnace, eh.
    Oct 2006
    Armidale NSW
    52
    915
    Quote Originally Posted by swarfless View Post
    Very easy to use and tuned itself very quickly ... pretty much hit the mark and kept the temperature variation tight (I seem to recall it was around +/- 1 or 2º at 720º).
    Cheers.
    Vernon.
    Dec 2005
    South Australia
    1,656
    A bit off the subject, I am about to build a small bench top furnace, any one have plans or know of any plans I can beg borrow or buy
  1. Another MARS lathe. Model Unknown.
    By hudnut in forum METALWORK GENERAL
    Last Post: 27th May 2015, 08:08 PM
  2. Furnace kit
    By AndrewOC in forum EBAY, GUMTREE, and other off forum sales sites
    Last Post: 28th Apr 2015, 12:29 PM
  3. Unknown brazing rods
    By phelum in forum WELDING
    Last Post: 4th Apr 2012, 07:24 PM
  4. Unknown Tool Steel
    Last Post: 26th Sep 2011, 10:34 PM
  5. Unknown Hercus 14x40 Lathe
    By JohnAXA in forum THE HERCUS AREA
    Last Post: 14th Mar 2011, 08:57 AM
