Results 1 to 6 of 6
    May 2013
    Toogoolawah, Queensland
    66
    44
    Default A Question About Pouring Cast Iron
    Screenshot.jpgOver on the woodwork forum, someone recently posted links to Matthias Burger's Youtube Channel. The subject of most of his videos is traditional 15th Century Wood Framed House renovation woodworking and renovating and using late 1800s and early 1900s woodworking machinery.
    However, two of his videos address making a wooden casting die, and then pouring some cast iron wheels. The following is the link to the "Casting an Iron Wheel" video.
    So - now the question. At the 7 minute 56 second point in the Casting an Iron Wheel video, just as the liquid cast iron is poured from the furnace into a big ladle, the ladle operator tips a cup of something into the liquid cast iron mix. The image at left is taken from that moment in the video. Does anyone know what would have been added at that point, and why ?
    Thanks,
    RoyG
    Dec 2005
    Canberra
    490
    I would presume limestone, to help separate the slag off the top.
    May 2008
    241
    Could it be bicarb soda (or similar) for degassing purposes?
    Sep 2008
    texas, queensland
    248
    ferrosilicon would be my guess
    'If the enemy is in range, so are you.'
    Feb 2009
    Adelaide - outer south
    67
    18
    A late reply I know but I've only just stumbled on to this forum.
    Texx is right, it would be ferrosilicon or a proprietary inoculant based on ferrosilicon.
    The late addition of a small quantity helps provide extra seeding sites that refine the structure and help reduce the likelihood of carbides in faster cooling areas like thin section/external corners. It's been a while since being involved with such things but I think the addition rate was somewhere in the order of 0.05 - 0.1 % of the metal weight.
    Tipping it into the stream coming out of the furnace is the preferred method of addition to assist even distribution.
    Cheers, Bob the labrat
    Measure once and.... the phone rings!
    Feb 2012
    Northern NSW
    1
    Quote Originally Posted by labr@ View Post
    I'd recommend going to YouTube and looking for videos by LuckyGen 1001 .Excellent stuff with lots on melting cast iron and furnace building.
  1. Replies: 8
    Last Post: 19th Jun 2013, 06:32 PM
  2. Cast iron VS Cast steel lathe compound slide
    By Ueee in forum METALWORK GENERAL
    Last Post: 23rd Dec 2012, 11:40 PM
  3. Cast Iron
    Last Post: 30th Apr 2011, 02:27 PM
  4. Milling Cast Iron
    By BurnMark_SandIt in forum METALWORK GENERAL
    Last Post: 22nd May 2008, 11:52 AM
  5. hard cast iron
    By hazard in forum WELDING
    Last Post: 23rd Oct 2007, 11:02 AM
