Results 1 to 7 of 7
Thread: Oil burner
    Nov 2012
    Mid North Coast NSW
    422
    Default Oil burner
    Hi all, Looking for info about making an oil burner for melting aluminium
    Nov 2007
    Near Rockhampton
    270
    Quote Originally Posted by phaser View Post
    Have a look at the alloyavenue website. Here's the link to the burner forum.
    http://www.alloyavenue.com/vb/forumd...er-engineering
    Lots of info here
    Ueee's Avatar
    Dec 2011
    Canberra
    39
    4,515
    I have an oil burner but never used it, it's from an old boiler. For ally though gas is more than enough and far easier to setup. If your in it for the challenge though, making an oil burner would be interesting.
    Oct 2006
    Armidale NSW
    52
    915
    I had a burner from an old central heating system, but found it unsuitable for use in a furnace, as it was designed to heat a bigger area and the confined space of a furnace just choked it.
    Cheers.
    Vernon.
    Dec 2007
    1,628
    Can you use a 9kg gas bottle gas forge and turn it upright to melt Alu for casting?
    Nov 2016
    Benarkin North, Queensland
    77
    7
    There are many ideas on Youtube, in fact I am going down that road, the oilman, from NSW, is quite the man when it comes to simple, seems the only hard part is building the foundry, and in most cases, he just uses a large oil drum with fire bricks. here are a few of his links: https://www.youtube.com/results?sear...te+oil+foundry https://www.youtube.com/watch?v=c39k04FhEEc https://www.youtube.com/watch?v=TUSOczTBkWU I have plans to cast rods for turning. Denis-Peter:
    Oct 2008
    Cairns, Q
    666
    You might find this thread interesting:
    Has anyone used a spinning cup oil burner?.
    Frank.
  1. burner help
    By fxst in forum THE FOUNDRY
    Last Post: 21st Jun 2013, 12:36 AM
