Results 1 to 7 of 7
15th Sep 2014, 05:07 PM #1Senior Member
- Sep 2009
- Newcastle
- 342
Newcastle Furnace Material Suppliers
I'm just starting my furnace build.
Plan is castable 1600ºC hot face, kaowool insulation backing, waste oil burning (the brute style design).
Hopefully someone else local finds this helpful
I spent quite a while trying to find suppliers without much success until a business referred me on to:
Beroa
303/1B George St
Mayfield NSW
(02) 4960 0441
I wandered in, and they are clearly set up for big jobs for industry, but they were extremely helpful. Michael assisted me and knew exactly what I needed.
$50 even for a 25kg bag of Duracast 1600AR ($83 at Field Furnace Refractories).
They also sell Kaowool, at about $100 for a roll of 50x610x3660 or 25x610x7320. I won't need nearly that much, so they advised me to pop in in a week or so, when they've finished a job, and they'll likely have some offcuts that I can buy.
I was contemplating freight from Sydney for this stuff, so it was a great find.
Now I just need to find a decent furnace shell.
15th Sep 2014, 05:27 PM #2Senior Member
- Sep 2009
- Newcastle
- 342
From: http://www.engsupplies.com.au/dense-castables.html
DURACAST 1600AR
DESCRIPTION:
A conventional cement bonded castable, which has good strengths and dimensional stability.
Maximum Service Temperature (oC) 1600
Dry material required per cubic metre (kg) 2140
Maximum grain size (mm) 8
Water addition (litre/100 kg) 10-12
MODULUS OF RUPTURE (MPa)
After drying at 110oC 12
After heating to 1000oC 8
After heating to 1600oC 12
COLD CRUSHING STRENGTH (MPa)
After drying at 110oC 50
After heating to 1000oC 40
After heating to 1200oC 90
PERMANENT LINEAR CHANGE (%)
After drying at 110oC neg
After heating to 1600oC -1.5
THERMAL CONDUCTIVITY (cast)
At a mean of 1000oC (W/m/oK) 0.85
Storage life (under ideal conditions) Twelve (12) months
TYPICAL CHEMICAL ANALYSIS (%)
Al2O3 SiO2 Fe2O3 CaO TiO2 Alkalies
56 37 0.6 4.8 1.5 0.4
20th Sep 2014, 06:36 PM #3Senior Member
- Jan 2012
- Hinchinbrook
- 112
21st Sep 2014, 12:05 PM #4Senior Member
- Sep 2009
- Newcastle
- 342
Phil,
I'd like a chamber size of 8-10". Planning 1" refractory, 2" ceramic wool.
I've seen lpg tanks used as shells - just need to find one, not sure where they go to heaven?
25th Sep 2014, 11:01 PM #5Senior Member
- Sep 2009
- Newcastle
- 342
Manage to snag a 9kg LPG cylinder (well actually tetrafluoroethylene, which is non-flammable) at a scrap place today. They had a skip full of 9kg cylinders. Had some bigger ones too (45kg I guess).
They gave it to me for free because they are not allowed to sell to the public...
Very nice of them.
8th Apr 2015, 02:48 AM #6Member
- Dec 2010
- Mornington Peninsula
- 97
Any progress on the furnace build and how it is all coming together?
Pictures would be great.
10th Apr 2015, 09:03 PM #7Senior Member
- Sep 2009
- Newcastle
- 342
Haven't got any further, been working on other projects.
Starting to plan again however, having been inspired by myfordboy on YouTube.
Small furnace
By Woodwould in forum METALWORK GENERALReplies: 5Last Post: 12th Jul 2010, 02:53 PM
