Page 2 of 2 FirstFirst 12
Results 16 to 29 of 29
Thread: Furnace build
  1. #16
    Ueee's Avatar
    Dec 2011
    Canberra
    40
    4,515
    Depends on how i mold them. I think if i make them flat as above i won't need pressure once the mold is up to temp. I would like do them with the feed on the edge however, so i can mold in the bearing registers etc and the feed is on the edge so any roughness left from cutting the riser off ends up covered in rubber. This way i will probably set up an extended steel riser and make a steel plunger and use a fly press or arbor press.....
    I was looking into ceracote to protect the dies but i think the hi-temp version is only good for 700C, not enough for full temp ally. My other thought was the spray on graphite lubricant, although once the mold gets hot the propellant may ignite.....
    BTW they are linisher contact wheel hubs.....
    Ew
  2. #17
    Dec 2007
    1,628
    How did you find the chips?? I was under the impression that they weren't a viable source due to the amount of surface area in comparison to the small amount of material. This leading to more slag than good casting material.
  3. #18
    Ueee's Avatar
    Dec 2011
    Canberra
    40
    4,515
    Hi Dale,
    I found the chips under the lathe.......
    I had heard that chips were not so good due to the large surface area and its potential for oxidizing. My mate that built the furnace suggested trying them and just making sure I had a good reducing flame. It seemed to work fine, although how it would go with another fuel is anyone's guess.
    These guys can forge weld without flux in a reducing atmosphere gas forge, pretty damn good evidence of just how little free oxygen is left in the forge with these burners tuned correctly.
    Ew
  4. #19
    Dec 2007
    1,628
    I meant how did you find using them not where did you find them
    Are these more grinder wheels your making? The previous one you outsourced the casting yeah?
  5. #20
    Ueee's Avatar
    Dec 2011
    Canberra
    40
    4,515
    Yeah i had 20 cast, the larger ones at considerable cost. I'm not so keen on making any more 14" wheels, if i do i will probably pay the price to get them cast again. The smaller wheels are not so bad, but i really want to get into die casting to cut the machining down. From the sand cast, mine or the foundries, i have had to machine 100% of the surfaces as they are too rough and not perfectly flat/round so i have to balance them. 100% machined means they are balanced perfectly, but of course takes time.
    Ew
  6. #21
    Ueee's Avatar
    Dec 2011
    Canberra
    40
    4,515
    Some pics of my first few cast hubs. These are molded in petrobond and poured with nothing but chips i collected from the lathe!
    The first one i ran out of ally, the second my riser was not big enough and it solidified before the hub did, meaning the hub pulled itself apart internally with shrinkage. These are a nice shape to mold as the rim is the thinnest part, follow by the plate and then the hub, meaning shrinkage is not so much of a problem.
    Still a few air bubbles after machining but getting there. Next stop die casting......
    Ew
    Here is the finished wheel from the above hub. 12"x2", 75duro serrated rubber, ground on the face and both sides.
    Ew
  7. #22
    Jun 2011
    bankestown, NSW
    8
    Default Serrated rubber wheel , How do you Do It?
    Hello Ewan
    Nice project building the furnace. Good to see your recycling of metals from your lathe/mills/shapers goes towards new toys and tools.
    Q. How do you go about creating / moulding the rubber and serrations onto your fresh machined metal wheel.
    Cheers Eka
  8. #23
    Jun 2007
    Ipswich QLD
    68
    1,997
    just skimmed through this coming back to read fully. After seeing the video of the rubber torture this is one to follow.
  9. #24
    Ueee's Avatar
    Dec 2011
    Canberra
    40
    4,515
    Thanks guys.
    The rubber is slotted on the mill with a dividing head. It's a bit of a pain to do but once you get the RPM's and feed right its not so bad.
    Ew
  10. #25
    Jun 2011
    bankestown, NSW
    8
    Ewan
    Can you elaborate how you get the rubber onto the machined aluminium.
    Do you bond it , glue it or mould from raw materials?.
    Reason being i have some old wheels that i would like re rubber and you method appears do-able in the home workshop.
    Cheers Eka
  11. #26
    Dec 2007
    1,628
    The rubber is cast on. The wheel goes in a large wgg ring and the rubber mixed and poured in around it and set. Later turned etc. Sounds easy but not as much as you think
  12. #27
    Ueee's Avatar
    Dec 2011
    Canberra
    40
    4,515
    Dale has it...but there are a number of tricks that i will not post on an open forum.
    The other issue for one offs is you need to using a bonding agent to get the rubber to stick and whilst you only need a tiny bit you need to buy a certain amount and it is not cheap, plus it is a DG so shipping is not cheap.....
    Once it is on you then have to machine it.....depending on the rubber this can be a nightmare, soft rubber would rather push out of the way than be cut, even with the sharpest of tooling.
    It is then best to grind the rubber concentric with the bearings.....
    It may sound easy but it's not. I've now done about 35 wheels, and still don't have it 100% right.
  13. #28
    Jan 2004
    Mackay North Qld
    6,446
    Ew
    Hmmm?
    Linisher belt pulley ,perhaps- or have a missed something?
  14. #29
    Jun 2007
    Ipswich QLD
    68
    1,997
    I knew there was someone who could use that ally I turfed recently.
  1. Furnace Build(likely to be very slow)
    By Stustoys in forum THE FOUNDRY
    Last Post: 15th Jul 2013, 04:18 PM
  2. FREE gas furnace
    By AndrewOC in forum THE SMITHY
    Last Post: 20th Jan 2013, 01:32 PM
  3. Diesel Powered FURNACE build
    By SawDustSniffer in forum THE FOUNDRY
    Last Post: 24th Oct 2012, 02:36 PM
  4. Small Furnace
    By foccacia in forum THE FOUNDRY
    Last Post: 31st May 2011, 11:24 PM
  5. Small furnace
    By Woodwould in forum METALWORK GENERAL
    Last Post: 12th Jul 2010, 02:53 PM
