Results 1 to 7 of 7
    Apr 2019
    Finland
    46
    117
    Default Skinning knife with limited tools
    Hi
    I made a bet with a friend.
    Could i forge a skinning knife from a file without
    Real anvil with a horn?
    File was 5mm thick and 38mm wide.
    Requirements for the blade was to make it
    Atleast 8mm thick from the back and 55mm wide blade.
    Geometry had to make by forging, grinding was
    Allowed to be used only for finishing and sharpening.
    Slower version from the Video: https://youtu.be/eIZ0CVjBPCU
    Used tools.
    Rr-track as an anvil.
    Two hammers
    Angle grinder
    Locking pliers & thongs
    Wet sanding paper
    Hadn't tried anything like that before, so it was a little tricky to do.
    Jan 2004
    Mackay North Qld
    6,445
    Hi Toumas,
    Nice knife, mate!
    I looks like you put many hours in to the polishing ,alone.
    What grit wet and dry did you finish with? #1200?
    Apr 2019
    Finland
    46
    117
    Hi Toumas,
    Nice knife, mate!..
    Thank you very much buddy!
    It took about 3-5 hours. So long that battery of my camera run out. I tend to forget that kind of things while making something.
    And yes i used 400-600-1200 wet sanding papers for finishing. Taped paper with masking tape to square tube, and tried to keep it on the same angle whole time.
    When edited all heating parts out from the video, actual forging took only 34 minutes. Whole video about forging was about 2 1/2 hours long.
    I used small gas forge for heating, but didn't expect that heating takes so much time.
    Time doesn't feel so long when forging.
    Dec 2005
    South Australia
    1,656
    Great job ( I'm guessing you one the bet)
    Apr 2019
    Finland
    46
    117
    Quote Originally Posted by China View Post
    Thank you. I won it.
    Now its my time to challenge him.
    That's actually quite fun, to make things that you haven't thought at all. One just gives you the subject and says how its must be done.
    Aug 2015
    QLD
    735
    After watching the video I made the observation that there must be some big trains your way.. I certainly look forward to watching more of your vids..
    ...As for cutting leather - Power hammer made Chinese kitchen knife cuts steel - (at the 8.15 mark) https://m.youtube.com/watch?v=PwTkMFeJE1I
    Apr 2019
    Finland
    46
    117
    Quote Originally Posted by YBAF View Post
    Yep. I don't where my friend found it, but i think its been under the crane..?
    Traditional track would possibly made working easier, that one was so shallow that it made using the edge little more trickier.
    But, its wider that traditional track, which made forging the sides easier.
  1. Bridgeport with limited electricals
    By caskwarrior in forum ELECTRICALS
    Last Post: 19th Jan 2017, 09:11 AM
  2. My turn to confess to buying something of limited use
    Last Post: 27th Feb 2013, 04:31 AM
  3. Sub forum issue with limited number of threads, maybe?
    By Canoath in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACK
    Last Post: 4th Oct 2012, 11:51 AM
  4. Stop paint skinning over?
    By neksmerj in forum THE HERCUS AREA
    Last Post: 23rd Mar 2010, 03:21 PM
