Results 1 to 10 of 10
    Oct 2015
    melbourne
    473
    Default Gas forge - external temp?
    G'day all
    Just fired up a long term project, a small gas forge based of course on a propane cylinder, this one was 5kg I think - a little smaller overall than a 9.
    I have 1" of ceramic wool with itc100 coating.
    The burner is a mikey style, 3/4" tube.
    The problem is the outside gets a lot hotter than I expected. Barely touchable after 3 or 4 mins, which was enough time to heat a 3/8 rod to bright red.
    Normal? Not enough insulation? More itc100?
    All advice appreciated..
    Russ
    -Russell
    Dec 2009
    Sydney
    327
    G'day Russell,
    sounds like a great project.
    I'd suggest at least another layer of Kaowool; see https://www.youtube.com/watch?v=1DyeESQpac0
    for what you can achieve with (4 inches of?) the stuff- a tin can that can melt cast iron!
    good luck,
    AndrewOC
    'Waratah' spring hammer by Hands & Scott c.1911- 20, 'Duffy, Todd & Williams' spring hammer c.1920, Premo lathe- 1953, Premo filing machine.
    Dec 2005
    Canberra
    490
    The rule of thumb that I have seen is that the wall insulation should be about one-quarter of the total diameter thick - so that's 25% insulation, 50% furnace area, 25% insulation.
    See this for the best introduction to the entire 'make things hot enough to melt' topic I've found to date (pdf file)
    The Hobbyist's Guide to Casting Metal--2nd Edition (print).pdf
    Oct 2015
    melbourne
    473
    I posted a reply yesterday but it seems to have got lost in the ether.
    I guess I'll have to add a second layer with another coat of itc100.
    I was just surprised by how hot it did get so quickly.
    Ps, thanks for the link to the casting book... Very informative.
    -Russell
    7,188
    The shell of my mains powered gas forge is 12" in diameter.
    It has a 2" layer of insulation so it has a 8" diameter cavity.
    This is what happens after an hour or so with one torch operating at full flow.
    I can put my hand on the outside of the back of the forge for about the first 15 minutes or so of operations.
    I generally don't run it for longer than an hour.
    Dec 2007
    1,628
    The guys that I know of all use 2" of Isowool, The isowool by the way comes in 3 heat rating as well as 1" and 2" thicnesses.
    Then rigidiser and a layer of castable ceramic. to seal the wool.
    I just fitted the isowool to mine today but haven't tracked down any itc100 or castable yet.
    Ueee's Avatar
    Dec 2011
    Canberra
    39
    4,515
    Just use satanite Dale. My "little pig" is 6" od with 1" of wool and the hard face, yes it gets hot to touch but it also keeps welding heat no problems without using much gas. No amount of insulation is going to be able to maintain a difference of 1200 degrees for long without so.e kind of active cooling.
    Dec 2007
    1,628
    Ewan is Satanite a castable refractory cement
    Ueee's Avatar
    Dec 2011
    Canberra
    39
    4,515
    Yes and you can also use it to clay blades for quenching to create hamons.
    Dec 2007
    1,628
    Nice
  1. Turning a L.H.external thread without an undercut
    By Alf Scotting in forum METALWORK GENERAL
    Last Post: 21st Jun 2015, 06:15 PM
  2. External Panel Option for HuanYang VFD
    Last Post: 14th Jun 2014, 02:25 PM
  3. External thead cutting tool
    Last Post: 8th Dec 2011, 07:32 PM
