Results 1 to 10 of 10
Thread: Cable Damascus
    Dec 2007
    1,628
    Default Cable Damascus
    Yesterday I spent about five hours at the forge making this cable into a solid bar along with another piece about half the length.
    It seems to have forge welded up nicely with no signs of inclusions or delimitations.
    I need to prepare an enchant. There seems to be great controversy over the best acids, or combination and strength/dilution.
    Hydrochloric, sulphuric, white vinegar, ferric, muratic.
    So not sure what I will use yet.
    Dec 2007
    1,628
    I forgot to mention that the bar reduced to bout a third the diameter of the original cable without much noticeable increase in length. Shows how much air is in between all the small strand twists and larger grouped twists making up the cable.
    Dec 2007
    1,628
    I drained some acid from an old battery and left it for an hour.
    Jan 2011
    Far West Wimmera
    63
    4,049
    I am waiting to see how it looks when finished.
    Aug 2015
    QLD
    735
    The concept were new to me so I had a look-see at google pictures. Some amazing knife work made from old cables. I'm looking forward to seeing whats made here.
    Oct 2001
    ACT
    667
    Looks nice. I have been wanting to give it a go myself. What process did you use etc. I have seen people combine a few length of cable - looks like yours was a decent diameter to begin with.
    Dec 2007
    1,628
    I'm wondering what it will look like finished too….I'm also wondering what it will be as I haven't decided yet.
    It's about 1" cable. The process is pretty simple.
    Use tie wire to tie off each and to stop unravelling, cut length off.
    Throw in coke forge heat to mid orange, coat heavily in borax and put back in forge, keep rotating the cable so it heats evenly and soaks through without burning the cable strands.
    Pull out and lightly set the end, brush off, coat with borax put back in forge, fireweld ends and shape square may take a few heats, repeat other end.
    heat whole length of cable to weld ing heat put one square end in vice and other in a shifter and twist the cable tighter. Brush..borax..heat. Start at one end and fireweld by hitting in a rotation following the cable Brush..borax..heat..reapt until solid. Forge to shape.
    Feb 2013
    Picton NSW
    82
    That is coming along really nice!
    Here is one of my cable damascus blades..
    Dec 2007
    1,628
    Yeah nice job!
    When are you doing a stall in melb next?
    Feb 2013
    Picton NSW
    82
    Quote Originally Posted by DSEL74 View Post
    Yeah nice job!
    I believe the next one down south is the Melbourne guild show on 30 April and 1st May.
    You should come up for a top weekend at the Symposium though in March.
    Worth the trip!
  1. Does this cable contain Asbestos?
    Last Post: 24th May 2015, 11:04 AM
  2. VFD Remote Cable
    By Oldneweng in forum METALWORK GENERAL
    Last Post: 14th May 2014, 07:39 AM
  3. Damascus/ironwood knife
    By ohno in forum KNIFE MAKING
    Last Post: 18th Nov 2006, 11:17 AM
  4. damascus steel pendant
    By ohno in forum METALWORK GENERAL
    Last Post: 11th Nov 2006, 02:34 PM
  5. Hydrochloric acid for Damascus?
    Last Post: 10th Oct 2006, 09:49 PM
