Page 5 of 9 FirstFirst 123456789 LastLast
Results 61 to 75 of 134
  1. #61
    Oct 2015
    melbourne
    473
    Quote Originally Posted by DSEL74 View Post
    I like that little clamp on vise with the star on it.
    It even has a tiny anvil at the back!
    Russ
  2. #62
    Oct 2001
    ACT
    667
    Russ, re your post#58, I think the word on the top at least is Joshua.
    checking my reference (Anvils in America) there is a Wilkinson Anvil marked down low like yours - Joshua Wilkinson Warranted.
    likely thats what yours is.
  3. #63
    Aug 2010
    Near Bendigo, Victoria, AUS
    72
    3,105
    Just finished a new rail-line anvil with my 10 y.o. grandson. I taught him oxy cutting on some scrap, them marked out the anvil shape on the rail line and let him at it.
    Don't worry, he got plenty of help and guidance - and supervision and was suitably kitted out. Sorry I didn't take any photos of the sparks and "lava" as he called it, but I kept my eye on him at close range instead....
    Between us we ground it clean, I put some weld beads on the curved top surface and then we ground it roughly level. The finishing touch was to surface grind the top and sides. With a lick of red enamel, it's now his pride and joy.
    Oh, I made him promise to pass it on to his grankids and tell them how we made it
    Cheers, Joe
  4. #64
    Jan 2004
    Mackay North Qld
    6,446
    Hi Joe.
    The young feller is very fortunate to have a grandad like you.
    It is something he will treasure and use and remember all through his life. It ticks all of the boxes.
    It sounds like he will be a hands-on type of kid.
    I dipss me lid to you ,sir!
  5. #65
    Dec 2007
    1,628
    Joe if you want to bring him around some time we can light the Forge and show him how to use it. Could even Forge him a little hammer head.
  6. #66
    Aug 2010
    72
    3,105
    I'm sure they would love to come and see you - and so will I. I'll ask them.
    I'll be in touch.
    Thank you for the offer!
    Cheers, Joe
    Cheers, Joe
  7. #67
    Feb 2018
    Perth. Australia
    63
    27
    Got lucky at a local car swap meet on Sunday and ended up with this 116lb Peter Wright anvil.
    Pretty rusty but cleaned up well.
    Wire cup on an angle grinder, tannic acid, boiled linseed oil and beeswax.
    Should protect it until I am able to start using it.
    Thanks to BobL for the tannic acid.
  8. #68
    Dec 2007
    1,628
    English Hundreds Weight (hundredweight) System:
    Typically the hundreds weight markings are seperated by dots but not always. These figures were stamped into the finished anvil and are often not very deep. The first figure to the left is hundred weights which equal 112 pounds. The next figure is quarter hundred weights which equal 28 pounds and the last number is whole pounds. The three are added together for the total weight. Examples:
    1 · 0 · 4 = 112 + 0 + 4 = 116 pounds
  9. #69
    Dec 2007
    1,628
    Default Show me your Anvil thread...
    The edges are pretty chipped and rounded.
    Make yourself a square block with good edges to go in the hardy hole.
    You can dress the edges on each side from sharp to larger radii.
  10. #70
    7,188
    Came up nice Mark - well done.
  11. #71
    Feb 2018
    Perth. Australia
    63
    27
    Just curious. How much can you pound on the hardy hole end of the anvil without causing any damage or breaking it off???
  12. #72
    Oct 2001
    ACT
    667
    there's no hard and fast rule for how hard you can pound on them without doing damage to the heel and horn. At just over 1cwt your anvil is certainly not massive but a nice useable size.
    You could use a 4lb sledge in the centre of its mass on hot iron without much concern. but you do need to be careful on the heel (hardy hole end) as you do see quite a few anvils where they are broken off.
    If you do need to belt the cr@p out of something using a hardy tool - make a striking anvil out of some thick steel plate.
  13. #73
    Dec 2007
    1,628
    A lot of anvils get the heel broken off by using ill fitting hardy tools. Basically an oversized wedge put through s undersized hole has to breakout some place.
    the hardy should always seat on the face of the anvil with no gap.
  14. #74
    Feb 2018
    Perth. Australia
    63
    27
    Thanks for the tips guys. Dsel that block for the hardy is it just mild steel? I think my hardy hole is 7/8" so will get some square stock and make a few tools. Maybe a hot cut tool
  15. #75
    Dec 2007
    1,628
    Quote Originally Posted by Mark F View Post
    Mildsteel would be just ok if your working hot mildsteel. You’d really want something a bit tougher and harder wearing. You can always weld the shank on hardy tools so you could buy a block of bisalloy and weld a shank on to do the trick.
  1. Anvil on e Bay
    By auscab in forum THE SMITHY
    Last Post: 28th Jan 2013, 10:34 PM
  2. SOLD: Anvil
    By ranga_rod in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 25th Nov 2012, 04:15 PM
  3. TASMANIA Anvil
    By rwatson in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 17th Apr 2011, 07:40 PM
