Page 3 of 3 FirstFirst 123
Results 31 to 37 of 37
  1. #31
    Aug 2004
    Perth Western Australia
    59
    84
    Default 84 lb BK
    This is my 84 lb BK.
    Laminated Merbau block with stainless fittings to stop the tannin corroding them.
    I put lead flashing between the anvil and block to dampen the ringing.
    It looked so nice I made a heavy steel base to stop the block being scuffed.
    So far I have only used it to do a bit of peening.
    Mark.
    I've become a tool of my tools.
  2. #32
    Aug 2015
    QLD
    592
    Quote Originally Posted by Poloris View Post
    This is my 84 lb BK...
    Nicely done.
    What do the "BK" stand for ?
    The best way to combat Global Warming Hysteria is via reasoned argument.
    http://joannenova.com.au
  3. #33
    Aug 2004
    59
    84
    Default Bradford and kendall
  4. #34
    Oct 2001
    ACT
    480
    That's a nice looking BK and block particularly on that block Mark
  5. #35
    Aug 2004
    59
    84
    Default Pimped my new anvil
    Iv'e traded up to a larger anvil, so I had to pimp this one too.
    The Anvil is a 75Kg WL Bassett.
    I haven't been able to find out much about them.
    The wood block was a dining table in a previous life and the base was made from a 1.5m length of curved stainless 17mm thick.
    All fitting are also stainless
    Striking it results in a satisfying low sounding clunk.
  6. #36
    Oct 2001
    ACT
    480
    haven't heard of a WL Bassett.
    It looks remarkably like a BK (Bradford Kendall) anvil.
    At a quick search it looks like Bradford Kendall purchased WL Bassett. Based on the BradKen history in 1970 they "Purchased marine equipment merchant, W. L. Bassett & Son Pty Limited. and commissioned their Port Hedland Plant. so it makes sense that its in WA.
  7. #37
    Jan 2004
    Mackay Qld
    3,978
    Here is an anvil I made.
    The deck is made from an offcut from a dragline bucket.
    The sides and base are cut from used welding 19mm welding coupons and shaped under a brake press.
    The hollow inside the base was filled with melted lead.
    It was made as a knife making anvil and has no pritchel or hardie holes.
    I estimate a weight of around 60 kgs.
  1. Anvil on e Bay
    By auscab in forum THE SMITHY
    Last Post: 28th Jan 2013, 10:34 PM
  2. SOLD: Anvil
    By ranga_rod in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 25th Nov 2012, 04:15 PM
  3. TASMANIA Anvil
    By rwatson in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 17th Apr 2011, 07:40 PM
