Results 1 to 8 of 8
25th Apr 2019, 01:06 PM #1Most Valued Member
- 4,255
bearings and pulleys..picture heavy
Pic 1. Concentric locking collar bearings $10.00 each
Pic 2. Bush’s - Taperlock pulley - free with any taper lock pulley
Pic 3. Bush’s - Taperlock pulley - free with any taper lock pulley
Pic 4. Bearings New but shop soiled. $10.00 each
Pic 5. Bush’s - Taperlock pulley - free with any taper lock pulley
Pic 6. Bush - Taperlock pulley - free with any taper lock pulley
Pic 7. Bearings New but shop soiled. $10.00
Pic 8. Alloy 2B section pulley. $20.00
Pic 9. Qty 2 Alloy Pulley $20.00 each
Pic 10. Qty 3 Alloy pulley $25.00 each
Pic 11 Alloy pulley $15.00
Pic 12 Alloy pulley $15.00
Pic 13. Alloy pulley $25.00
Pic 14 Alloy pulley $25.00
Pic 15 Taperlock pulley SPB 100/3 (100 diam 3 belt) $20.00
Pic 16 Taperlock pulley SPB 150/2 $20.00
Pic 17 Alloy pulley 4inch 2A 3/4 bore $20.00
Pic 18 Taperlock pulley SPA 100/1 $20.00
Pic 19 2 off bearing mounts and bearings $50.00
Pic 20 SPZ 150/1 Pulley $20.00
Pic 21 SPZ 230/1 Taperlock pulley with bush 25mm $30.00
Pic 22 SPA 100/2 Taperlock Pulley with 1.5 inch bush
Most photos have description or further info. All pulleys are new as were removed from units at time of start up and replaced with others. All bearings are new.
If not sold in the bin they go.
20190425_094448.jpg20190425_094514.jpg20190425_094646.jpg20190425_095245.jpg20190425_095420.jpg20190425_095432.jpg20190425_100126.jpg20190425_101353.jpg20190425_101527.jpg20190425_101640.jpg20190425_101843.jpg20190425_102238.jpg20190425_102430.jpg20190425_102517.jpg20190425_102623.jpg20190425_102929.jpg20190425_103108.jpg20190425_103337.jpg20190425_103641.jpg20190425_103820.jpg20190425_104239.jpg20190425_104449.jpg
Will post if required at buyers expence
Can pick up Adelaide 5076
2nd May 2019, 05:09 PM #2Most Valued Member
- 4,255
Take 50% off
2nd May 2019, 05:10 PM #3Most Valued Member
- 4,255
Take 50% off all prices.
2nd May 2019, 06:51 PM #4Philomath in training
- 6,540
I thought I'd already put my hand up but I'll take the bearings and bearing holder lots. Don't have a use yet...
3rd May 2019, 07:27 PM #5Most Valued Member
- 4,255
4th May 2019, 12:58 AM #6Most Valued Member
- 5,942
Hi Richard, How much would you want, for what you have left there, just don't want to see them "dumped"?
4th May 2019, 05:12 PM #7Most Valued Member
- 4,255
All besrings and both mounts have sold.
Kryn ...all available as per above...else i will melt down...when furnace is finished...minus the one I am holding for you.
7th May 2019, 06:09 PM #8Most Valued Member
- 4,255
Not much joy in getting rid of pulleys but they should be available in the future..years probably...i have plenty of alloy scrap so wont need to melt this stuff in the near future....
So keep this ad in mind for several years
Boring timing pulleys
By snowyskiesau in forum METALWORK GENERALReplies: 9Last Post: 28th May 2015, 08:53 AM -
Poly-V step pulleys
By Ironwood in forum METALWORK GENERALReplies: 16Last Post: 4th Jun 2014, 03:42 PM -
Making Dickson style quick change tool post holders (picture heavy)
By Dave J in forum METALWORK GENERALReplies: 40Last Post: 9th Apr 2013, 11:15 PM -
pulleys
By welder in forum THE HERCUS AREAReplies: 6Last Post: 2nd Nov 2010, 11:03 AM -
Pulleys and bearings
By jmk89 in forum METALWORK GENERALReplies: 0Last Post: 6th Mar 2008, 02:48 PM
