Results 1 to 11 of 11
Thread: Old Scroll Saw
21st Oct 2018, 08:02 PM #1Diamond Member
- Sydney, NSW
- 1,249
Old Scroll Saw
Hi,
Australian made Scroll Saw.
Just needs motor and mounting to a board.
Please see pictures.
Asking $40.00
Pick up Central Coast NSW or Hills District, Sydney.
19th Apr 2019, 03:25 PM #2Member
- Sep 2016
- Canberra
- 87
HI, not sure if the Scroll saw is still available, but if it is I will be up Newcastle way on Monday?
Kind regards
Matthew
19th Apr 2019, 08:41 PM #3
I'm also looking for a scroll saw...
So I'll put my hand up too.
However,
I can't figure out from the photos how this one works. The bow appears to be a solid casting and part of the base. How is the top of the blade held tight and move with the eccenter at the bottom (or whatever makes the blade move)?Cheers, Joe
20th Apr 2019, 12:02 AM #4
I had a quick look at the pics Joe, and my take on it is similar . I think the overarm is solid and stationary, and the cylinder on top includes a vertical slide, a piston or bellows to provide air for the puffer, and a substantial spring to keep the blade tensioned. The crankshaft at the bottom operates a pushrod to a vertical slide mechanism and lower blade mount, ensuring that the blade motion is purely vertical.
I'm just not sure that it would qualify as a scroll saw while fitted with section of hacksaw blade as shown, as I suspect that the minimum cut radius would be quite large.I used to be an engineer, I'm not an engineer any more, but on the really good days I can remember when I was.
20th Apr 2019, 09:13 AM #5Diamond Member
- Sydney, NSW
- 1,249
Hi,
The "scroll" saw is still available.
However, it's (and me) are in the Hills District now. Pick up is welcome. Can be posted I guess.
TWIS, I thought it was a scroll saw but I could be wrong (often).
Ben.
21st Apr 2019, 12:28 AM #6
Could it be a dier filer / filing machine? Just curious....
Cheers, Joe
21st Apr 2019, 10:04 AM #7Philomath in training
- 6,540
21st Apr 2019, 01:46 PM #8Golden Member
- Cairns, Q
- 666
Joe,
FWIW many years ago (1949?) my father wanted a power saw, and settled on a heavy duty scroll saw type of saw as the cheapest alternative. He bought a kit consisting of a similar upper fitting to the one in the scroll saw photo as described above by malb, and an unmachined bronze eccentric strap casting. The kit was designed to be used with 1 1/2" pipe and fittings for a frame, and the upper fitting was clamped into a 1 1/2" pipe tee with a 3/8 brass bolt. The square spring-tensioned plunger in the upper fitting was split to accept the blade and had a 3/16W screw which went through the blade, and when tightened clamped the blade firmly between the two sides of the split. Machining the eccentric strap and making the eccentric was an early project for the near new Brackenbury and Austin lathe.
From memory the upper fitting was about 175 mm long, and its position in the pipe tee could be varied to adjust the spring tension or to accommodate blades of various lengths. I remember we used to use bits of band saw blade or hacksaw blade with the ends annealed and drilled for the 3/16 clamp screw. For fine work we did use fret saw blades with the pins removed, but can't remember how we clamped them in place.
For years this was our only power saw, and cut a lot of timber, and occasionally brass plate and sections. Mounted on the brick workshop wall it ran completely trouble free for many years powered by an old 1/4 HP ex-washing motor.
Frank.
22nd Apr 2019, 11:05 PM #9
So this could well be the "up-market" version of the DIY version your dad built.
I'm pleased to learn that it could be used for any kind of blade - and re-register my interest in this machine...Cheers, Joe
23rd Apr 2019, 05:25 PM #10Diamond Member
- Sydney, NSW
- 1,249
24th Apr 2019, 06:46 AM #11Diamond Member
- Sydney, NSW
- 1,249
Machine sold to Joe.
scroll saw blades for metal
By stonemason3 in forum METALWORK GENERALReplies: 3Last Post: 7th Aug 2010, 06:57 PM -
cutting metal with a scroll saw
By maree in forum METALWORK GENERALReplies: 4Last Post: 28th May 2010, 09:37 PM -
I am having to scroll horizontally on threads/posts
By jow104 in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 14Last Post: 20th Jul 2008, 05:32 PM -
Scroll bar colours - not happy.
By arose62 in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 3Last Post: 13th Mar 2003, 10:19 AM
