Results 1 to 8 of 8
Thread: 240v electric motor
3rd Sep 2018, 10:49 AM #1
240v electric motor
This motor was off the bench saw project which i scrap. $20
3rd Sep 2018, 12:53 PM #2
I’ll take it, subject to HP and pick up location.
Cheers.…..Live a Quiet Life & Work with your Hands
3rd Sep 2018, 01:07 PM #3
3rd Sep 2018, 02:45 PM #4Member: Blue and white apron brigade
- 7,183
5A @ 240V = 1200W -20% for efficiencies = 1080W = ~1.5HP
3rd Sep 2018, 10:50 PM #5Senior Member
- 112
Bob, I would be surprised if the motor shown is more than 1HP. I think your assumption of 20% losses for inefficiencies is being rather conservative, given the class of motor and the fact that it is four pole. On the practical side I have a similar CP 1.5HP motor which is rated at 7.1 amps. I would expect a similar four pole motor to draw 7.5 to 8 amps.
Chas.
3rd Sep 2018, 11:29 PM #6Member: Blue and white apron brigade
- 7,183
You are right my calc above is wrong
It should be 5A @ 240V = 1200W -20% for efficiencies = 960W = ~1.29 HP
Working backwards from your motor 240V @7.1A = 1.7kW = 2.28HP rated at 1.5HP = 65% efficient which is on the low side, more like a low class 1/2 HP motor. I've measured the actual HP and efficiencies of a few 4 pole motors (including some relatively elderly ones) around the 1kW output level at the rated current and never seen one with that low an efficiency.
The usual efficiency I measure is around 80% which is consistent with this chart.
My experience is that HP output ratings printed on motors are fairly nominal - and on small motors often stated to the nearest and higher 1/2 HP. interestingly none of the cheap chinese motors I have measured have output less than their stated HP.
4th Sep 2018, 07:26 AM #7Senior Member
- Near Rockhampton
- 270
4th Sep 2018, 10:01 AM #8Member: Blue and white apron brigade
- 7,183
Compact half hp 240V motor
By GDD in forum METALWORK - Machinery, Equipment, MARKETReplies: 2Last Post: 26th Jul 2018, 04:29 PM -
Electric Motor
By robbo37 in forum METALWORK GENERALReplies: 22Last Post: 18th Jul 2014, 09:21 PM -
kiss a VFD a good bye . now you can run 3 phase motor on your normal 240v main
By thorens in forum METALWORK GENERALReplies: 19Last Post: 30th Nov 2013, 05:39 PM -
SOLD: 3 Phase 240V/415 0.75KW motor
By Ch4iS in forum METALWORK - Machinery, Equipment, MARKETReplies: 6Last Post: 14th Jun 2012, 05:51 PM -
VFD for 240V single phase motor
By neksmerj in forum METALWORK GENERALReplies: 2Last Post: 25th Feb 2011, 07:13 PM
