Results 1 to 5 of 5
2nd Jun 2018, 10:12 AM #1Most Valued Member
- 4,890
Tee Slotted Cross Slide to suit Hercus Imperial Lathe 260/9".
This is a Tee Slotted Cross Slide that will fit a Hercus 260 Imperial lathe or 9" Imperial lathe.
The Cross Slide is new, it is not a casting it has been machined from solid.
It comes with a Cross Slide Nut and Gib to suit.
If used on a 9" lathe tool post will sit 5/32" higher than standard.
Price $380.00 plus postage or pickup.
2nd Jun 2018, 10:56 AM #2
I'm guessing this won't fit onto a metric Hercus 260...? Or, is it a matter of machining a new cross slide nut?
2nd Jun 2018, 01:02 PM #3Most Valued Member
- 4,890
A new metric nut would need to be made,you would not be able to use your original nut as the dovetail was mistakenly cut oversized.
The thread for the cross slide nut would need to be offset 1 mm from centre.
2nd Jun 2018, 01:41 PM #4
Thanks Pipeclay. First time purchasing. How do I progress with private discussion?
2nd Jun 2018, 05:55 PM #5Most Valued Member
Private message Him. When you click on Pipeclay, a box opens up with View Profile, under that is a title Private Message,
click on that, it'll open another box, in which you can then send a message to him, when that's done, click on submit message.
When he answers, there will be next to Notifications, (next to Welcome then your name) a number which will indicate that there is a message. Click on the Notification box and another will open with the message in it, click on the private message, and it'll open, which can then be read.
To answer, type your message in the box below it, and then press submit message, make sure you click submit message, otherwise it won't work. DAMHIKT
Hope this helps,
Cross Slide Scraping Hercus 260
By Abratool in forum THE HERCUS AREAReplies: 3Last Post: 14th Nov 2014, 05:06 PM -
Backlash in Hercus 260 cross-slide
By jack620 in forum THE HERCUS AREAReplies: 15Last Post: 4th Mar 2013, 06:19 PM -
Hercus 260 Cross-slide play
By jack620 in forum THE HERCUS AREAReplies: 19Last Post: 26th Sep 2011, 08:47 PM -
South Bend/Hercus Cross slide nut
By YarrD in forum THE HERCUS AREAReplies: 2Last Post: 14th Dec 2010, 11:34 PM -
Adapting quick change tool post holder to suit Hercus 9" lathe
By neksmerj in forum METALWORK GENERALReplies: 10Last Post: 10th Jun 2007, 10:37 AM
