Results 1 to 6 of 6
24th Apr 2018, 08:07 PM #1Member
- Sep 2016
- Canberra
- 89
Cincinnatti Toolmaster Turret Mill
For sale is my Cincinnatti Toolmaster Milling Machine.
Good old machine. 3 phase. Power feed on both X & Y axis. Power downfeed on quill. Has been modified to take ER 40 collets so tooling is cheap and abundant! Pretty good shape for it's age! One small woopsie on the table (not me) see pics. The table is 36" x 10" with a working/clamp area of 30"x7", which is 914mm x 254mm & 762mm x 178mm respectively. I was going to set up an inverter to run it but never got around to it. Only selling as I cannot fit it into my workshop (it was always going to be tight), very regretful! This is a very serious machine! Inspection welcome!
Asking $2400 (that's what it owes me) and would like to see it go to a good home!
Matthew
IMG_20180423_181027.jpgIMG_20180423_181213.jpgIMG_20180423_181008.jpgIMG_20180423_180958.jpgIMG_20180423_181132.jpg
24th Apr 2018, 08:31 PM #2Most Valued Member
- Jul 2016
- 35
- 1,522
By modified to use ER40 do you mean the spindle has been completely altered and no longer uses any kind of drawbar, just a nut? or does it have some kind of quick change tooling in it?
24th Apr 2018, 08:47 PM #3Member
- Sep 2016
- Canberra
- 89
Hi, the Cinci toolmasters never had a drawbar. They used the monoset collet system with large retaining plate and a locknut. Not a bad setup but the monoset collets were fragile and very expensive. The monosets use the nt40 taper in the same way as the er40 does so what the previous owner has done was to machine the retaining plate to accept the ER collets in place of the monosets. The spindle is unmodified. Kind regards Matthew
24th Apr 2018, 09:23 PM #4Most Valued Member
- Jul 2016
- 35
- 1,522
Thanksn for the explanation thats pretty interesting. Is there much backlash in x and y, does it have a back gear? Sorry for all the questions, I doubt I can come up there but maybe another buyer wants the info.
25th Apr 2018, 09:37 AM #5Member
- Sep 2016
- Canberra
- 89
That's quite alright. Currently it has about 17thou of backlash in X and y. It has anti backlash feednuts fitted so this can be adjusted to suit the operater. I simply have not had the time to get that done.
As far as back gear goes, it doesn't have any a back gear as such but rather it has a toothed belt secondary reduction which will accomplish the same speeds but will be much quieter and smoother than a traditional bull gear reduction drive.
It's an interesting setup.
Regards Matthew
20th Dec 2018, 09:26 PM #6Member
- Sep 2016
- Canberra
- 89
Mill sold
Installing a Turret Mill.
By Old Croc in forum METALWORK GENERALReplies: 10Last Post: 23rd Aug 2017, 11:15 AM -
Toolmaster mill
By markgray in forum METALWORK GENERALReplies: 44Last Post: 21st Apr 2016, 09:28 AM -
Bridgeport turret mill on ebay
By steran50 in forum METALWORK GENERALReplies: 5Last Post: 16th Mar 2010, 10:36 PM -
nice little turret mill on ebay
By bollie7 in forum METALWORK GENERALReplies: 0Last Post: 23rd Sep 2008, 08:58 AM -
Turret Mill
By sinjin in forum METALWORK GENERALReplies: 4Last Post: 22nd Nov 2006, 10:56 AM
