Results 1 to 14 of 14
    Jul 2007
    332
    Default Taylor Hobson Cutter Grinder
    Taylor Hobson Model G engraving / D bit cutter grinder 240 volts in very good condition for age, runs smoothly, complete with a diamond grinding wheel and all holders for taper and straight shank bits along with all cams for relief angle grinding, some are duplicates.
    Original operators handbook and operator instruction card looking for $600.
    Prefer pickup Perth, but may consider boxing for freight at buyer cost, estimate total weight around 20Kg.
    Any questions let me know. Thanks.
    Dec 2017
    Tatachilla
    63
    29
    What condition are the brgs?
    Jul 2007
    332
    No audible noise from bearings when running only wind noise from wheel and nothing noted when turned by hand.
    Dec 2017
    Tatachilla
    63
    29
    What do you reckon freight to Adelaide would cost?
    Jul 2007
    332
    Not sure, its a long weekend in WA so can inquire on Tuesday, but reckon all up around 20Kg but will weigh it in the meantime to confirm. Suspect it would have to go by road freight.
    Dec 2017
    Tatachilla
    63
    29
    Quote Originally Posted by C-47 View Post
    Agreed, let me know how you go.
    Jul 2007
    332
    Ok actual machine only is 21.5Kg based on bathroom scales + packaging say around 8Kg so reckon around 30Kg. I have a short video of the grinder startup and running but it too large to post (20mb) if you want to PM me your email address I can try and send it.
    Dec 2017
    Tatachilla
    63
    29
    If you can post to here for total of $600 I can afford to take it off your hands.
    Otherwise I'll have to let it slide.
    Cheers alby
    Jul 2007
    332
    Can you give me your postcode and shall see what freight is tomorrow. Private message me your info would be best.
    Aug 2010
    Near Bendigo, Victoria, AUS
    72
    3,102
    5039
    Dec 2017
    Tatachilla
    63
    29
    5093
    Jul 2007
    332
    Alby / Joe thanks.
    Aug 2010
    72
    3,102
    close
    Jul 2007
    332
    Item sold and making its way across the Nullarbor. Thanks.
  1. No.3 tool and cutter grinder
    By allterrain50 in forum THE HERCUS AREA
    Last Post: 25th Jun 2014, 12:32 AM
  2. Taylor Hobson Mirco Alignment Scope
    By Ueee in forum METALWORK GENERAL
    Last Post: 9th Jan 2014, 10:43 PM
  3. Another Tool And Cutter Grinder
    Last Post: 13th Nov 2013, 12:15 PM
  4. Tool and Cutter Grinder
    By Jors in forum METALWORK GENERAL
    Last Post: 17th Oct 2012, 07:32 AM
  5. Tool and cutter grinder
    By 12teethperinch in forum THE HERCUS AREA
    Last Post: 3rd Nov 2010, 03:49 PM
