Results 1 to 5 of 5
Thread: 59 HSS BA taps
6th Dec 2017, 09:30 PM #1Senior Member
- Feb 2016
- NSW
- 117
59 HSS BA taps
I have a collection of BA taps I don't need. All are HSS. All quality brands - Sutton, P&N, Ezicut, TEC etc. There is at least one sharp useable tap in each size, and several (if not all) in the larger sizes. Most are quite old (it is BA), and have had some surface rust or pitting at some stage, but all are now cleaned and oiled ready for use.
0BA 6
1BA 7
2BA 6
3BA 4
4BA 9
5BA 3
6BA 8
7BA 5
8BA 4
9BA 4
10BA 3
Looking for $50 posted for the lot.
7th Dec 2017, 10:11 AM #2Golden Member
- Cairns, Q
- 666
PM sent.
Frank
7th Dec 2017, 11:29 PM #3human termite
- Jul 2007
- sandstone point queensland
- 69
- 182
how did you clean them? I have about 200 I i want to clean,up to about 40mm wide, and about 100 dies ,most are P&N ,then i want to then list them
11th Dec 2017, 01:44 AM #4Senior Member
- Feb 2016
- NSW
- 117
Taps now sold, thank you all.
Robyn,
The hard way, unfortunately. A Dremel and a few of those little wire wheels. HSS is pretty hard so when it does corrode you either get not very deep surface rust, or pinprick pitting, so the rust either comes right off immediately or it you can't touch it. Just takes patience and getting on a roll, sadly. Doing 60 was tedious enough, I don't envy you
You could use a phosphoric acid bath, but I'm not sure what effect that would have on the overall sharpness of the taps/dies, and in my opinion phosphoric acid usually requires manual cleanup with a brush anyway to remove the... film it leaves.
24th Dec 2017, 09:20 AM #5
Metric Taps M3 - M12 as a set
By caskwarrior in forum METALWORK - Machinery, Equipment, MARKETReplies: 3Last Post: 9th Nov 2016, 02:17 PM -
Which Taps would you buy?
By ventureoverland in forum METALWORK GENERALReplies: 29Last Post: 30th Jun 2014, 08:32 PM -
Does anyone own some ACME taps?
By Michael G in forum METALWORK GENERALReplies: 14Last Post: 2nd Jul 2013, 11:12 PM -
taps and dies
By doug3030 in forum METALWORK GENERALReplies: 23Last Post: 10th Mar 2012, 01:44 PM -
BA taps
By morrisman in forum METALWORK GENERALReplies: 9Last Post: 23rd Sep 2011, 05:16 PM
