Results 1 to 15 of 17
Thread: Surplus items to go
7th Oct 2017, 04:01 PM #1Philomath in training
- 6,540
Surplus items to go
EVERYTHING SOLD!
Thread now closed.
Had a look through the shed today and there are projects there that I will never get to, or things bought as a good idea that never happened, so a bit of a clear out. These will probably end up on Ebay sooner or later but you guys get first look. If you like the look of something but not the price, talk to me. Conversely, if you think the price is too low, you are welcome to give me more.
Everything can be shipped but some is heavy...
First up is a dental spot welder - bought to do thermocouples, but it is 110V, missing a fuse holder and I could not find any instructions for it. $100
Deep hole drilling set up, complete with 9/16" bit. I've never run it because it needs 3 phase and I only have 1 3 phase outlet in the shed (which I would need for the lathe). Needs a plug. The pump motor is bloody heavy. Say $250?
Nikken quick change tooling for a 40 taper mill. I used it once for doing some repetitive stuff and it is nice. The only piece missing is the holder for the cutter collets. The agent has been meaning to fix it for me for the last 4 years... I can get it back but it is missing the needle rollers. When he took it he told me that they had some spare (metric) collets too. $300
Another box. This one holds a Waldown C1 toolpost grinder with the internal spindle too. Single phase; it ran last time I turned it on. $300
12 litre parts washer - yes, you can get them at Supercheap for $135, but this one will only cost you $50. I've only ever used it as a tank, so I can't recall whether the pump works - I think it did. (there's probably some bonus sludge in the bottom too, in case you need more)
Last up is a Cutler-Hammer mushroom E-stop. It works, I just replaced it because I prefer the twist to release style. It has both NO and NC contacts so you could use it on a VFD to turn on (pull out) and turn off (push in); $20.
ALL SOLD!
Thread now closed.Last edited by ubeaut; 22nd Dec 2018 at 05:57 PM.
7th Oct 2017, 09:10 PM #2Most Valued Member
- 5,942
Hi Michael, I'll grab the parts washer, Thanks.
Will do an EFT and grab next time I'm down.
7th Oct 2017, 09:13 PM #3Golden Member
- Jul 2011
- 837
8th Oct 2017, 12:30 AM #4Most Valued Member
- 5,942
Sorry Eric, the rules are, to say on the market place forum "I'll take it, PM sent". Not the other way around. Sorry, rules is rules.
8th Oct 2017, 10:15 AM #5Philomath in training
- 6,540
Eric, Kryn - PM sent.
Just so it is on record, I do have some thinking about the deep hole rig
8th Oct 2017, 10:27 AM #6Most Valued Member
- Australia east coast
- 2,713
9th Oct 2017, 03:13 PM #7Senior Member
- Aug 2013
- 229
Hi Michael
I am interested in the tool post grinder.
PM sent
Peter
9th Oct 2017, 05:30 PM #8Golden Member
- Aug 2012
- Australia
- 645
I will give an Expression of Interest in the toolpost grinder if it does not work out with Petip.
9th Oct 2017, 05:51 PM #9Philomath in training
- 6,540
More TPG pics
From the bottom of the bush to the wheel centre is around 35mm, but the bush protrudes 10mm from the casting and would be adjustable if it was cleaned and lubricated.
I plugged in and turned on and yes, it did run.
10th Oct 2017, 06:32 PM #10Senior Member
- Aug 2013
- 229
Hi Michael
Maybe I'll grab the E-stop whith the TPG, Message sent
cheers
Peter
10th Oct 2017, 07:47 PM #11Philomath in training
- 6,540
So far the parts washer, TPG and deep hole drilling set have been spoken for.
Left is the 40 taper QC mill tooling, the dental welder and the E stop.
I have been expecting Stuart to grab the dental welder to go with is collection of more unusual medical devices...
10th Oct 2017, 09:11 PM #12
Michael,
Petip has hinted that he would take the E-Stop, if he changes his mind then I'll take it.
Rgds - Gavin
10th Oct 2017, 09:14 PM #13Philomath in training
- 6,540
Yep. E-stop is now gone.
11th Oct 2017, 02:54 PM #14China
- Dec 2005
- South Australia
- 1,656
Interested in the dental welder, i won't be back in Adelaide till next week, if you want put a hold on it I will take it
11th Oct 2017, 05:29 PM #15Philomath in training
- 6,540
I have have a possible on the dental welder but I'll put you on the list as second up.
Myford Ml7 lathe items.
By lantain1982 in forum METALWORK GENERALReplies: 11Last Post: 18th Apr 2016, 08:29 AM -
Small horizontal mill surplus to my needs
By PDW in forum METALWORK GENERALReplies: 3Last Post: 28th Oct 2013, 08:55 AM -
suitable surplus source for right angle worm drive gear box ?- power hacksaw
By desbromilow in forum METALWORK GENERALReplies: 7Last Post: 6th Dec 2012, 05:45 PM -
Items for Sale
By Scott in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 19Last Post: 22nd Feb 2012, 09:22 PM -
Pictures on forum items
By QbnDusty in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 5Last Post: 8th Jun 2006, 03:18 AM
